03 Viper
MrSled
Site Admin/CEO
Staff member
Weston WI
Website
www.totallyamaha.com
Here is a crashed 03 Viper that I am rebuilding, nothing fancy really other then some bling and a 128 Mono, extension, custom cooler and extension.
Here she is torn down in several stages. With the final chassis completely stripped and cleaned.
Finally getting sometime to work on this project again. I spent the past few weekends installing a skid in an Apex XTX and adding power steering to a Venture EPS.
Working on the running boards and installing the Mono 128 Brackets.
I was going to mention doing my board mod but I see you already installed some covers.
I have some pipes and head if your going to go piped?
Not sure if I want to go that route or not... might want to leave her stock. Not sure if I want the headache of pipes. I was hoping to build the Viper the way I wanted the SX-R to be when it was released with the Red Head motor and wanted a single piped power valved motor.
Finally put a little more time into my Viper build. I added the tunnel extension for the 128" Mono, Retro fitted a Nytro bumper to the extension.
Then we put new bearing in the chain case, changed speedo side bearing and mounted up the track and jackshaft. I really wanted to get that mono skid in place to be sure everything was put in correctly....and it all worked out.
I also started to work on the rear plastic cover. Needed to notch it out for the tunnel extension. Working on a custom mounted rear exchanger and plumbing.
Next up will be to get the old girl on her skis ;)!
Hey sled any chance you can measure the width of that bumper? Trying to see if it would fit the width of the hartman tunnel extension on my apex. Thanks love the build!
I will try and get you a dimension tonight... also you can post your dock stuff on this side as well.
