skidoostan
my kid has a 2000 phazer a i put a riser on it ...now the throttle cable is too short ...they dont make a throttle extender for it ...anybody run into this yet ...this is only a single cable not a double
A couple of bucks
Hello Stan and welcome aboard. How much did you raise the bars?
richierich
You can try rerouting cable and gain some slack.If you look on the steering column there a metal hoop that cable runs thru.Take it out of there and route it the shortest distance to throttle block.Let us know what size riser is on there.
skidoostan
3 inch...i did some checking and a mountain lite cable is still too short...powermadd doesnt make an adapter for this set up ...looks like i need a custom made cable.if i had about 6 more inches it would be perfect
i have a friend that makes custom cables. if your interested i could give him a call and see if he can help you out.
pm me how long it is and if you have a picture, I might have something that will work.
send picture to betheviper1@gmail.com
skidoostan
i will send it in the morning ...thanks
I would be intrested in a custom made throttle cable.snowdad4 said:I have a friend that makes custom throttle cables.
If you are interested I could give him a call and see if he can help you out
Please post some pictures on his custom made throttle cables !
A couple of bucks
You'll definately need a custom cable w/ a 3 incher.skidoostan said:3 inch
skidoostan
I found a guy down south that builds cables for ultralight aircraft and sent the cable to him ...keeping my fingers crossed
A couple of bucks
He's gonna add 3 inchs to the length of the cable you sent him....right. To make up the 3 inch riser. I'd hate to think that you left that out. Sounds like something I'd do though.skidoostan said:I found a guy down south that builds cables for ultralight aircraft and sent the cable to him ...keeping my fingers crossed
skidoostan
i had him add 5 inches ...the guy builds cables for small aircraft with sled motors
A couple of bucks
I seem to remember our venerable Vmax 4 engines were either FAA or EAA certified for ultralights.
skidoostan
Got the cable back and the guy did a great job ....cant tell it from a factory cable and it fits perfect ...feels like a whole different sled with risers
Post some nice pictures of the custom made throttle cable.skidoostan said:Got the cable back and the guy did a great job...
cant tell it from a factory cable and it fits perfect...
staggs65
what was the cost for that cable if you dont mind sharing?
skidoostan
right around 68 bucks ...cable was done right
