Srx440 roundslide carbs
CAN,T SAY BECAUSE AGAIN, WE SHELF-ED THE YAMAHA PRIMARY FAST FOR COMET 102C. VERY HARD TO BELIEVE THE YAMAHA PRIMARY WAS BETTER THAN A COMET. BUT YOU TESTED IT. COMET,s WORKED ON MY SRX,s. 3:16 (YAMMIE TONY)
orchie18 said:
The comet 102
As long as you can give up some weight, (and rev a bit higher) about all you can do is "notch"
orchie18 said:
Any set ups for the yamaha clutch? Parts may be a little more available within our time line
If you decide to try the Yamaha clutch let me know. I have various flyweights and spring tuning kits avail for the SRX (PM me if interested)
WOT
notching weights is some what of a art ...you need to fully understand it before attempting it as you can make junk of a perfectly good weight and a little goes a long way ............if you have a perfectl good comet then get you self a set of polaris 10mr's and lighten to 39.5 grams and use a 140/300 primary spring like a EPI or TEAM red ........with stock secondary set at 120* twist
