why aren't you out riding mod.I am going soon myself..
AaenSRX
Sunday I'm going riding in the hills and all this deep snow we got. Should be a good day like u said. Sled will be working hard where I'm going. Hopefully I've got this beat now. I'll let you guys know how it goes.
remember the SRX don't like deep snow,you will be overheating them clutch's and belt for sure.
bluemonster1 said:why aren't you out riding mod.I am going soon myself..
im moving there blue ...probably the last weekend here ....melt melt melt
Vt Srx
If your new belt is chirping you need to shim your secondary to let it drop down in your clutch a little.
tons of snow here.took out the XTC piped 700 with 1.5 track today..wow it was fun not getting stuck..Love the sled,punch it from a stop and lifts skis to 11 o'clock position..wicked.Climbs the hills all the way up catwalking,skis never touch..love the pull with the triple SLP pipes on this redhead 700modsrx said:im moving there blue ...probably the last weekend here ....melt melt melt
AaenSRX
Typical. Go out riding on Sunday. Excited to see how the new clutching would work. Blow the bottom bearring in the chain case. Just my luck this year
staggs65
AaenSRX said:Typical. Go out riding on Sunday. Excited to see how the new clutching would work. Blow the bottom bearring in the chain case. Just my luck this year
Thats a "Wicked Pissah" as we say here in Maine. But checking all driveline bearings as part of your Preseason maintenance will put an end to these failures. nothing worse than ruining a ride over a $12 bearing.
shigawaker
That bearing might have also been contributing to alot of your problem...
Do u take out the shims out on the back of the secondary?Vt Srx said:If your new belt is chirping you need to shim your secondary to let it drop down in your clutch a little.
AaenSRX
Yes. The three little washers. Thats what I read online to do. Put a new belt on and broke it in. Put about 100 km on it. Put the washers back in started squealing again. So I took them out and kept them out. Had no problems since. Am I doing something wrong?
thats fine..
