Gerryjackman
Ok I paid 420 bucks for three f*** I ordered the whole cage assembly not just petals is that all I need they didn't say they were reed blocks I just told them what I wanted and he mentioned reed cage?
Gerryjackman said:So I took my cylinders into local yamaha dealer and there telling me there no good to use any more and all the coating is off the cylinders and they need to be re coated I guess I really need help here they want 350 a piece to re coat or order refurbished cylinders for 300 a piece pleeeease help is that even possible I wanna make sure I'm not getting screwed around here
as if the coating was completely gone and so few miles..guys are running with 20,000 km's on original motor not opened up yet.If you can see the cross hatch there..they should be good to go..unless you have chunks missing in the cylinders. ou can pu good used cylinders on here for $150-$175 even.I would not spend over $1000 for cylinders..then add pistons and rings on top of that..Gerryjackman said:So I took my cylinders into local yamaha dealer and there telling me there no good to use any more and all the coating is off the cylinders and they need to be re coated I guess I really need help here they want 350 a piece to re coat or order refurbished cylinders for 300 a piece pleeeease help is that even possible I wanna make sure I'm not getting screwed around here
