More pics!
All thats left to do on this old girl is;
-Relocate the front of the skid to get it on the ground
-Get the saddless Apex skis from JDViper machined out and mounted, Thanks again Jason!
-Get a windshield, Find krylon fusion that matches the blue on the hood, paint and install
-Get hardware for the tail light and get that installed
-Bolt the seat down
-Get a rear bumper/tunnel extension on (this thing will be going 136 soon)
-Get the heated grips working
-Register it and ride the
out of it!
Had the original tool kit in it complete with everything its supposed to have. Put the auto adjust brake on from the SRV and cleaned up the chain case and oil tank.
Had a hell of a time with the cooling fan.. The original fan was loose on the shaft and the XLV/SRV fan is larger in diameter. Took a spare XLV fan to a buddies, chucked it up in his lathe and turned it down to size.
Clutches gone through, Carb gone through, new oil/fuel lines, Replaced the air box and carb boot with a nearly mint unit I had "in stock", scraped the gunk out of the pan and pressure washed it. Also thoroughly cleaned the motor up and painted the cover.
Inside of the hood after cutting the holes and getting the strut covers mounted up. The holes were cut using the template that I have made and have available to duplicate.
Rough cut outs for access to the front skid bolts. These will get cleaned up once the skid is where I want it. Im going to have to drill a third hole another inch down from the one the skid is located in now to regain the correct geometry.
'98 Vmax seat from my XLV fitted up ready to be bolted down once the tunnel is finished and the tail light is in.
Got the scissors on and shimmed today. Nice and tight but I have one loose outter tie rod end that needs to be replaced to take all the slop out.
And the ever so popular 3/4 rear shot.
