Ok so I got everything out and apart. I have upper and lower bearings and seals, the bearing at the top of the chaincase cover, speedo bearing, 2 set screws for the bearing because they were missing, speedo needle, chaincase gasket and a bunch of other goodies on the way this weekend. I know I need to remove those ring clips that hold the bearings in on the back part of the case to remove the bearings, but how do I get that one bearing out at the top of the chaincase cover?
