sxviper-s
What is this Armorcord? The link did not work. I take it it's much tufer than stock? Where can I buy this? Thanks
yamahamark
Armor cord is a tough rope and is a p.i.t.a to cut good stuff. I bought some cobra cord this year and it to is a p.i.t.a to cut. Both cost about the same but cobra you can get different colors.
http://www.iceageperformance.com/armor-cord-snowmobile-replacement-cord.html
http://www.cobrapullcords.com/collections/cobra-cords/products/snowmobile-cobra-cor
A couple of bucks
A couple of bucks
Who makes those flat gas cans? I remember seeing them once but cannot for the life of me remember the name. I'm thinking of making a seat riser that will have one of these fitted between the tunnel & the seat.
super1c
Super Moderator
Im sure there are more but this was the brand i was thinking of. http://www.motorcycle-superstore.co...e=&network=g&gclid=CK3D9KXZss8CFYOEaQodPvcH_A
sleddineinar
Is thing assembled yet? I'd love to see pictures of the final product!
klopin also makes a similar style can. i use one on my apex. brothers use the rotopax on theirs.
A couple of bucks
Thanks guys. Nothing even started yet. I'll need to get the can first and go from there.
A couple of bucks
A couple of bucks
A couple of bucks
A couple of bucks
A couple of bucks
Vincent
Well-known member
Looks great.
A couple of bucks
A couple of bucks
A couple of bucks
Dalton? I’m guessing that the Y on the box signifies Dalton’s Y series helix.
Can anyone confirm?
Can anyone confirm?
mustangmatt
It was under the "ceramic exhaust coatings" tab. But I can no longer find the satin. I'd probably pick the "gray ice ceramic". I like the way that looks.
If someone does do the ceramic coating, block off all vents entering the hood. Ya don't want cold air blowing on that freshly painted pipe before it is FULLY cured. It will peel if ya don't tape them off. Just drive for an hour or until the temp light comes on. Then remove the tape from the vents.
Hey how did the Ceramic coating hold up on your pipes? Also do you have more details of how you applied it and the curing process? Thanks!!!!
A couple of bucks
It was a two step cure in the oven. The third and final cure needs to be done on the sled. 1100ish degrees. Vents blowing directly onto the pipe need to be deflected or taped off. Cold air blowing directly onto a pipe that has not had its final cure WILL result in peeling in that area.
It is a pretty much normal wet application. The stuff is nasty and you will most definitely need a respirator. Vacating the curing area during the first two cures is mandatory. Smoking and stinking to Hi-Heaven is an massive understatement.
It held up great. I haven’t seen the actual surface of the pipe since it got Header Wrap and silicon taped. Nothing holds the heat in like header wrap. The silicon tape all fused together when I fired it up. Those three things combined really really hold the heat inside the pipe. We’re talking...being able to leave your hand on the pipe for @ 5 seconds or so immediately after riding.
A couple of bucks
