drew24
slop would mean bore is too big for the piston. Must be like that from the factory
thanks , i understand...
therefore Wiseco be a good idea ....
I can not find the 8CA pistons, finally, I found but they do not deliver in France!
A couple of bucks
There is a second part number on the parts diagram. Is that an oversized piston?
https://partstream.arinet.com/Mobil...nvzcj2wjKGp9ienb0c5UlFYb3HyigYAtdZBGOko1.html
A couple of bucks
A couple of bucks
Have you taken a SNAP GAUGE and gotten a measurement on the bore diameter of the cylinder?
Avoid the yamaha pistons or be very selective. The first version were known for failure.
A couple of bucks
You are talking about the Pistons manufactured back in 97. Right.Avoid the yamaha pistons or be very selective. The first version were known for failure.
PMaine, are you referring to the 1997-up 600 twin pistons, or the 1994-1996 600 twin pistons?
edit
Dang you 2 bucks, beat me to it!
edit
A couple of bucks
I wasn't aware of any problems with the 94-96 Pistons.
Wow yes I am speaking about 1997. Sorry about that. 8c r 00 is what I had for OEM pistons that failed In my 1997.
Hey, it's good to have it cleared up, helps everyone that is interested. Your 8cr-00 pistons likely haven't been available since way back then unless someone has kept 'em that long or in an engine that has never had them updated. I would think Yamaha's updated 8cr-10 pistons would be fine to use in 97-up applications unless someone can advise otherwise.
For JAPET's purpose, as long as your cylinders and pistons are within size spec and aren't scratched or damaged, they should be fine to use. If you need to replace pistons, I'd try to find the 8ca's that you are referring to, along with new rings and anything else that needs to be replaced. The 8ca pistons are still reasonable priced making them an even better choice.
Yamaha Nutz
Little tip I got from Olav himself years ago on the trail twins run the 8-8200 rpms you will see way better performance
A couple of bucks
I have read that as well. Get them in the 8100 ballpark and your golden.Little tip I got from Olav himself years ago on the trail twins run the 8-8200 rpms you will see way better performance
I am enough this view, thanks.
You mean I have to lower my rpm of about 300/400 ?
A couple of bucks
Isn't the sled reving to 9000 and finally settling in at 8500? If so, I'd have to say it's spring related. But you are running a non-Yami primary spring so I cannot advise. What is your helix?
it's quite that.
spring is the Aaen calls for these pipes.
I also yami spring green pink green.
Helix stock, 41° I believe ..
no trail in my country, full mountain and backcountry. read elsewhere that your 8450 rpm ...
