brianbailey440
looking for some sound advice about clutching, and gearing.i have a 2000 sxr 700, 115 hp i believe.tried a few differnt weights in the primary.started with stock weights 8df00 3.7 rivet in both holes, and the sled reved 9,000 rpm.46.5 grams . same weights with 3.7 rivet in the tip, and 4.5 in the second hole ,and it reved to 8,600 rpm.47.3 grams.tried a set of 89a-10 weights w/ no rivets, 9,000 rpm. 48.7 grams. added 3.5 to the tip, and 8,300 rpm. 51.8 grams. same weights, added a .83 to the first hole, and 8,000 rpm.52.6 grams. sled pulled much harder with the 89a-10 weights, but i still wasnt happy, so i tried a set of 89l-17605-00-00 with a 2.6 rivet in the only hole, and 8,200 rpm. forgot to weigh them, lol.the sled rips when it gets traction , 1 inch track, 97 sx gearing, 8dn belt, secondary at 70 degrees.my question is should i gear lower to get a higer top speed ?am i reving the correct rpm for that stock motor ?.stock pipe, stock motor, no mods.should i put a set of v-force 3 reeds in it?is it worth the $ ?your input is much appreciated !!! thanks, brian.
