viperhauck
Hi. Want to change the cdi just to know if its bad or not. I have a 2001 srx and have a 2002cdi. Now that they dont have the same part # and dcs.....but do that cdi works anyway?
I would suspect the 2002 CDI in the 2001 will allow the sled to start and run but performance will suffer as the 2002 CDI will be operating as though it has a defective or missing Detonation sensor.
If I have my 2002 SRX's DCS switched off its a dog.
viperhauck
The full story is that I bougt the sled for 2 years ago and it was completly stock with only 4500km on the speedo. Did the clutchwork with w-w-w loaded 8dn and 52/46 Dalton helix, the sled ran great and was fast. Before last winter I send the the case,cylinders and head to mrviper 700 for a complete porting job with racecase. Along with that I have 38mm mach Z carbs. Other mods is complete viper front end and Lynx pps skid with 38mm track. Viper reverse and boss seat. After all this mods it drops rpm in higher speeds and bad backshift. Have triple check the powervalves, also locked them open just to try. Tried lots of different clutch setup. heelclicker and many differnt springs/helix/weights. Differnts clutches, both primary and secondary. Have check tophatfilters in carbs. Jetting, Changed reeds. Tried the stock carbs. looked on the fuelfilter in tank, seems ok. Open up the fuelpump. Checked the crank and is 120 degrees between tdc. Checked and recheck the harness for damage. My next step would be to change some electrical and see if one Component is bad.
When I did all the mod I noticed that one of the popnut that holds the hoodstrap was loose so I welded it back. Maybe something happend there??
What are you using for a TPS....I found TPS voltage at full throttle to have a huge effect on my 2002 SRXs full throttle performance.
roudyroy1
Did you unplug the cdi before welding it?
Devilin AblueDress!
I am a noob compared to you Bob but from what I have read on here that was my first thought also.
viperhauck
Have the oem tps connected to the harness but not in use. However I think thats not the problem. Have the same issue when I tried the oem carbs with tps in use and yamalars on this forum dont use the tps either and he dont have this problem. What do you say yamalars?
viperhauck
No I dident. That is why I want to try with a different cdi
Devilin AblueDress!
Seems unlikely unless sled was running (or key was on) while you were welding. Suppose your better off to rule it out and have correct CDI on hand as a spare though.
yammitrip1
mine bogged on top and had really bad back shift when my center to center distance was incorrect between the clutches.
viperhauck
C-c is correct and also the belt tension
you would need a 01 srx cdi, 2002 wont work right without the dcs all hooked up.
I doubt you did anything to harm the cdi with welding on it if it still works, if it didnt work that would be the reason as the welding would have grounded/shorted the circuit.
The cdi controls the timing so it is possible it has a problem looking at the list of things you checked already. find a 01 box
yamalars
Ýepp mine have the same engine mods exept i have add a 3 degree key and bender 835 pipes, no tps. Runs really great! Didn't notice much (if any?) diff. when i added the key tho, but i'll guess it will help topend performance as the peak is at 8800 now with the benders? And i'm almost done with my custom tps bracket/linkage for the tm38's. But i dont dare try it with my key already in there? But i will send one to viperhauck for testing.Have the oem tps connected to the harness but not in use. However I think thats not the problem. Have the same issue when I tried the oem carbs with tps in use and yamalars on this forum dont use the tps either and he dont have this problem. What do you say yamalars?
viperhauck
Tonight I have tested to change fuelpump to a sx pump. Change filter in tank. Switch all electrical behind left plastpanel included the cdi. No difference at all. Have 9000rpm off the line then 8500 then after 100km/h starts to drop to 8000. Maybe my clutching also is of now. But is hard to tell because its never have hold 8500 all the way matter what I havd in the clutches. For now its 8ca loaded with 4.5g both holes. Oem spring with one shim. Engage 4000-4100. Hauck v (51-45) helix with green @ 80
viperhauck
are you sure the track is not ballooning under the gastank and rubbing? look from the back of sled with flashlight at under the gastank area.
viperhauck
Not 100% sure but tension is good but will check that
viperhauck
What do you think about the clutching don? Tomorrow I going to test a 50/40 helix
what all helix angles do you have??
with coded helixs usually its not what you think or have been told for angles.
viperhauck
Hauck V, Maxperf. 50-40, Bender 51-43 I Think, OEM, Dalton 52R-46, Noname (black)54-47 and shockwave with 8 degrees cutting
