viperhauck
Hi. Want to change the cdi just to know if its bad or not. I have a 2001 srx and have a 2002cdi. Now that they dont have the same part # and dcs.....but do that cdi works anyway?
What are you using for a TPS....I found TPS voltage at full throttle to have a huge effect on my 2002 SRXs full throttle performance.
Did you unplug the cdi before welding it?
No I dident. That is why I want to try with a different cdi
mine bogged on top and had really bad back shift when my center to center distance was incorrect between the clutches.
Ýepp mine have the same engine mods exept i have add a 3 degree key and bender 835 pipes, no tps. Runs really great! Didn't notice much (if any?) diff. when i added the key tho, but i'll guess it will help topend performance as the peak is at 8800 now with the benders? And i'm almost done with my custom tps bracket/linkage for the tm38's. But i dont dare try it with my key already in there? But i will send one to viperhauck for testing.Have the oem tps connected to the harness but not in use. However I think thats not the problem. Have the same issue when I tried the oem carbs with tps in use and yamalars on this forum dont use the tps either and he dont have this problem. What do you say yamalars?
are you sure the track is not ballooning under the gastank and rubbing? look from the back of sled with flashlight at under the gastank area.
