New tunnel extension installed and cooler reinstalled. Took out the rivets in the way for the front bracket. I can't hold that bracket in place and drill it all at the same time by myself and don't have a clamp that can fit on there. So I'll have to get someone to help me finish that up.
Because the rear of the cat skid is wider than the Yamaha tunnel bracket in the center section where it's strongest, I think I will use some steel I have here and make a bracket that will go outside of the stock rear bracket and have mount holes where I need them.
