Trying hard to remember. There are 2 torque sequences for the primary. No reason why I can't put the primary back on.
Had to go back to the book.
85 and 43 ft lbs
Sent from my SAMSUNG-SM-G920A using Tapatalk
85 and 43 ft lbs
Still the same issues. Should I swap secondaries?
Hauck orange in primary with 89a 10's hauck silver at 80 with a straight 49
brianbailey440
id try that,and check your bushings. helix bushing, and primary cover
brianbailey440
what is the secondary spring set at?
drew24
If you have another one try it. At least then you would know if it is the secondary or the primary.
80
Helix is new
Earlier the secondary shifted out while leaving the yard and brought me to a screeching halt
drew24
Ouch! I bet that was a fun surprise.Earlier the secondary shifted out while leaving the yard and brought me to a screeching halt
It was a slow roll just starting out
drew24
That's not so bad then. Thinking out loud here but if the secondary all the sudden downshifted it would have to be because the primary stopped pulling it right? Not sure on that but it makes sense in my head anyway. lol
Still the same problem after swapping the clutches
yamahamark
This is the same problem I'm having and I'm starting to wonder if it might be my belt.
Tried diff. belt too
brianbailey440
check the motor mounts,maybe you have a broken one
brianbailey440
cog bearings?jack shaft bearings?suspension?im stumped
drew24
Guessing you swapped both clutches? Does it do the same thing on a stand? Can you roll the track by hand if its on a stand?Still the same problem after swapping the clutches
brianbailey440
i think 80 is too tight, i like mine at 70, or 60.the clutches could be fighting each other. try it at 60, 3 and 3.or try another set of clutches that you know work.and pull up on the primary clutch to see if you have a broken motor mount
Still the same. Sec. On there now is at 70
