Total mystery. It's only grabbing around 7000 rpms or so.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Time to pull the servo cover
brianbailey440
you mean engaging at 7000?put a stock primary spring in .you should engage at about 4200 rpm,sounds like a primary problem to me,try that
No it only revs to that rpm
brianbailey440
did you change anything on the primary since it was running good before?if you have a short cover primary clutch with a long cover primary spring, then theres your problem,make sure it has the right spring for the clutch.if you still have the old spring, then put them side by side, and look at the length of the springs, you will know right away.
I changed nothing. New springs but it's doing the same thing. Something is not making power somewhere
brianbailey440
did you test the stator?
brianbailey440
heated shield wire grounding out?
I thought the hauck orange is made up of 5 coils not 4Primary doesn't look too bad.
I have new springs on the wayView attachment 60001View attachment 60002View attachment 60003
Ok,
I have a cold pto pipe. Good spark
On the jackstand I can get it to shift at 7500 rpm and then will eventually climb to 8500.
All the cables felt nice and pushed in nice under the servo cover. The servo and cables moved nicely while idling below 900 rpm
Couplebucks probly thinks something not good got sucked up in there runnin that old SRX out of gas
brianbailey440
take a look at the reeds, i know its a pia, but pull the carbs and look at the reeds just to be sure
Youllbe2nd
Have you checked compression or done a leak down test?
Sent from my E6560C using Tapatalk
brianbailey440
good advice, id check that too, might as well start with the basics, and check everything, the only way your gonna figure this one out
drew24
Also check crank seal with carb cleaner. Easy thing to rule out
Has new pistons and rings
Youllbe2nd
Did you try bypassing tors? Sounds like you've eliminated clutches...My other guess would be powervalves
brianbailey440
id still check compression,did you check it after you rebuilt it?
brianbailey440
also, you never said if you checked the stator,if you did, what were the readings?
