You not supplying enough detail will get you an answer like that. Ill let you figure it out.The leaking is on top of the cylinder head. It comes through by a head stud, I checked thatNot sure how the leakage of a manifold gasket would end up there? But now I'm open for just about any explanation, because if the gasket had a tear on it it would for sure let out the coolant.
odds are the bottom of the stud is in a coolant jacket and needs new teflon sealant to stop the coolant from going up the stud.
Thanks, but that seems more like gas to me.
You sure its not coming out the spark plug?
Yes, I am, I saw it (and heard it) fizzling from the nut nearest the boost bottle.
rip it down and put a new base and head gasket and move on.
It's ordered. I just cant understand how the oil and gas gets past the gasket, but not the coolant, oh well we will see.
Seems like the head is warped, now it leaks coolant. What year v-max is the hauck thin headgasket from?
I dialed in the tempaflow on the venture once more, and what a difference, just turning that screw made the sled run much harder and the mileage went from 9,5 mpg to about 11, 11,39 is the record now.
I do not get it why the gps shows the same whether the sled shows 145 (90) or 153 (just under 94) on the speedo. Why? The gps shows 82,6 mph or 133 kmh
Spinning the track and you are really only going 82.6 LOL
with at 600 twin, @ 90mph and a 136 track, for sure not spinning the track, lol
I know but fun to mess with wegie lolwith at 600 twin, @ 90mph and a 136 track, for sure not spinning the track, lol
Agreed!
Yea, but an explenation? I don't get this at all, LOL
500 twin.with at 600 twin, @ 90mph and a 136 track, for sure not spinning the track, lol
Oh, that’s right. And you also have a 600 SX, i just remembered seeing the pic of your 600 head that was spitting gas or coolant.
Yea spitting through the headgasket, that is fixed now. Yes that's one of my other sleds.
NorthofSixty
Don’t know if this will help but I know I have my gps is set for a 10 second data record interval for general tracking purposes. I would have to hold top speed for at least 10 seconds to be sure it is accurately recorded at this setting. For a speed run I would set it for 1 second interval so I don’t run out of lake.Yea, but an explenation? I don't get this at all, LOL
