SpiderViper
I can't decide and does any one have both? I really want to know what the best way to spend my money is
Thanks, Chris
Thanks, Chris..SNAKEBIT..
1 vote for triple pipes, but I also long tracked it 136 x1-1/2 and I love it
Modzilla
Pipes pipes pipes IMO
yamaholic22
Expert
Steven DeMarco
- Feb 16, 2004
what is your biggest complaint? ride or power? i have the expert x and love it.
in my opinion it is a fantastic addition. both have pros and cons. really depends on you.
i have read about a lot of people with tripple pipes having a lot of problems.
obviously you can't just bolt on pipes and go. you will need to rejet your carbs. probably want to update clutch with a kit. add a rear heat exchanger if you dont already have one. with the added horsepower i would recomend installing a torque arm
the list goes on and on.
if you install the expert x it is a little bit of work but the payoff is huge and all you need comes with it. no hidden costs or things to update or modify later.
when i bought my viper i was thinking about the the pipes too but i went with the expert x and i am positive i made the right choice.
ViperTom
Expert X.....I put a 136" Expert X with a 9819 track and CPR pipes on my 02' Viper. I put the Expert on first and was amazed at the difference....it hooked up great, Zero track spin off the line. I put the pipes on and I couldn't get it to hook up as well but the extra power was nice. You will see the best improvement with the Expert X off the line and more top end improvement with the pipes.
Tom
Tom
jimmie d
The pipes will give you top end but you will sacrifice mucho mpg and reliability plus not get a thing back when you sell. The Expert X does not have a downside and improves resale.
Jim
Jim
I have both Pipes and expertX.
Love both, but it depends on what you want more. More Power and speed=>pipes; Better suspension and better hook-up=> expertX
Pipes will cost you MPG, expertX will sacrafice the slot car like on rails feel in the corners when on the gas.
Allvipedup
I don't know what your guys are doing, but my pipes have effected my gas mileage minimally. I love the power and it's not just top end I found dramatically increased power through the entire power band. To each his own, but I love the pipes and I plan on getting a 136" expert X this summer.
jwiedmayer
I have both on a sx. If you don't mind fooly around with pipes the fun factor increased a lot more with the pipes than with the X. But its a close 2nd.
SpiderViper
Thanks alot guys i realy don't know what to choose but i think that it might be the expert x but i love the idea about the pipes for the power. The reason that i was looking at the X is because they don't kill your gas milage
. I saw someones post that said that it really didn't.
SpiderViper
So far the tally is 5 for the pipes and 5 for the expert i will probably go with wich ever you guys suggest the most of.
jimmie d
With the pipes you will drop from 15 MPG to 10 MPG or lower.
Jim
Jim
SpiderViper
Oh that is not as bad as i thought i thought that it could be as bad as 5 or 6 mpg. Thanks Jim
Chris
Chris
SpiderViper
What kind of price for the expert x and for the total package of Slp Pipes?
..SNAKEBIT..
When I went out west, I used the same amount of gas as poo 700 and 800 stock sleds,
less then a skidoo 800 summit (old body) and more then a MM700 peak head & can
this was after a day of tweaking! was pig FAT to begin with
yamaholic22
Non-cermaic coated the pipes will run you around $800, and that is if you don't order their clutch kit for the pipes as well. With ceramic coating (which i recommend), they will be around $1,000 (again, without the clutch kit). An expert will run you in the neighborhood of $1400 for the setup, maybe $1500 depending on who you can get it from.
SpiderViper
Thanks i would def. like to get the ceramic coating just because it looks sooooooo gggggrrrreeeaaattt
i have it done on my old 500 phazer because we piped it and it looks sweet
How much does the clutch kit cost?
How much does the clutch kit cost?SpiderViper
By the way I have been meaning to tell you; You have a nice avatar and so do you SnakeBite
SpiderViper
I like yours also Jim very original And so is AllVipedUp
