03viperguy
wow, thats a lot of pretty neat info that I didnt know about those old x sleds
guess you have a more unique sled than I had originally thought
skidooboy said:even though i am biased i believe mine is super unique. i have added oil injection, low comp domes, had to go to #5 base gasket as this motor was tight from the factory (160 psi with low comp domes), custom clutching from northern catalyst (dynamo joe fame), stretched skid rails to 136 with mountain machines rail extensions (with 8" wheel config), mountain machines billett wheels in the whole skid, the upper rear oem cross shaft idlers were offset so, i had to machine the rear cross member tube and then get spacers to get the proper axle spacing required for a non offset billet wheel, stretched tunnel to 144 had to have the extension custom fabbed as they don not make one for the zx X chassis, rear bumper from a summit highmark rev (24") rear rack from a mountain cat with the proper doo tail lamp. chromed the trailing arms, usi project X skis, egts, water temp gauge, custom graphics where the number plates go. ect.... i like the sled, just needs more power upstairs. lol! the zxX race chassis is quite a bit different than the consumer version as well, stiffer, wider boards, more bracings. it's is a light fun sled to whip around on in the deep, and the trails it is a point and shoot rocket. it is the funnest sled i have been on zero to 70. ski
familyman said:Thats my kind of riding....great group, little off trail exploring and just a good time by all!
