power valves..no big deal here.....
SRX-SKI said:
When adjusting with the 2.5mm allen wrenches, do you just keep them gaskets in between the two housing? when adjusted right, does the freeplay stop just enough for the 2.5mm to fit in?
Yes gasket stay's in,you can't remove it without taking the housing apart.
you loosen the cables all the way up up @ the servo motor then unloosen
the two allen bolts on the housing, insert your two 2.5mm allen wrenches
then go back up to the servo and gently take up the slack in the cables,(one at a time,carefull not to over tighten) it'll pull the housing up against the allen wrenches,when it just tuches stop, it's good enough.
Alright, thanks for getting it out in the open. Helps alot more, I never got the manual when I bought my SRX. THANK's guys.
local yam mechanic uses a coat hanger bent in a u shape so he can adjust without spacers droping into the belly. check size with your calipers or you could get yourself a wire draw machine and some diamond dies and make a bunch of sizes.. the wire does make it a little easier good luck
