valin
Dan did great with his 600 improver. Since it was his first weekend with it running hard, he had alot of tuning to do, and managed to run 128.0 with it, at the end of the day on Sunday, in mushy conditions. The winner in the class ran 130.9 in the morning, when the ice was hard and fast. I believe he would have won the class if he had a bit more time. He'll be on top next event for sure.
As for me, I'm still having issues, although it is much better. I ran a best of 149.1, but the sled is still laying down mid track. I was pretty well unable to run or tune it on Saturday due to rough conditions, so I really only had Sunday to work with it. Judging by the way it leaves, it'll have 60's in it for sure....I just have to figure out the laying down issue....it'll just take time.
valin
Picked up a new Weather meter.
Kestrel 4250. Not cheap, but this baby meters everything. It's a must have for what we have coming
formulated
vdo
ryan it's norm i'm looking for a tach any idea where?
valin
VDO on amsnow right now with a battery setup and charger for $200. If i had the cash, I'd buy it.
formulated
vdo
its in the works as we speek
valin
Excellent. Good choice. The VDO's are a very nice piece, and I will be buying one for my prostocker.
formulated
egt
Ryan what do you think of the egt tack from 2koolperformance
valin
I looked at them before. I would still go with the VDO over the EGT. The VDO can easily be calibrated to run on anything. I am not sure about the EGT tach.
I ran an Autometer tach before, and the tach was out, and the only way to calibrate it was to send it back to Autometer. I just ended up getting rid of it. I don't recommend them.
formulated
ryan
any testing tomorrow
valin
Nah, i'm done for the year. I'm going to work out the rest of the bugs on the dyno, when it arrives
Danger Dog
Good luck with the vdo. I have one that works fine and another that is newer that the needle fell off. The egt's are spot on at least the ones I have seen.
valin
The Kestrel 4250 arrived today. What a great tool.
This thing does everything. It measures:
-Temperature
-Dew Point
-Moisture content
-Heat Index
-Wet Bulb temperature
-Humidity
-Wind Speed
-Pressure
-Altitude
-Air Density
-Density Altitude
-Relative Air Density
Here, we have terrible air.
-Temperature
-Dew Point
-Moisture content
-Heat Index
-Humidity
-Wind Speed
-Pressure
-Altitude
-Air Density
-Density Altitude
formulated
ryan
was out at rockys on sunday tom ran a 139.7mph with the f111 the ice was good
valin
Yep, I heard. Whittaker is hosting an event on Sunday. I threw on a speed track and did some chassis work on the trail sled, so I'm planning on running this weekend with it. If the ice is as good as it was this past weekend, I figure I'll pull some good numbers.
makes me wish the war was together. ah well cannot bitch at the speed of free labour.
formulated
ryan
i need to get more fuel in it tom think my bog near the end is a fuel issue
formulated
my av says im a junior member mini ha ha
valin
You are far from mini. I have all of your jets here, Norm. Give me a call if you want them before the weekend.
yamajohn
I was also out on sunday and there was a 50' X 100' about a 100' off shore from the north west tip of blueberry island, scared the sh?t out of me!!!
formulated
Ryan
It's ok not a jet issue must be in carbs as i put a electric fuel pump and same problem runs out of fuel near 1500 to 2000ft mark
