Danger Dog
LB what size carbs are you running. Those look like Phil Stanley pipes, did he do your msd? Also is the water rail on top of the heads custom or can you get one somewhere? I have a price 1000 that I run on the ice.
Danger Dog said:LB what size carbs are you running. Those look like Phil Stanley pipes, did he do your msd? Also is the water rail on top of the heads custom or can you get one somewhere? I have a price 1000 that I run on the ice.
here is some viper hood supports that i made to fit my srx. they were less than half the weight.pro116 said:That should lighten it up.Are you going to take the stock boat anchor ski's off and put some sly dogs on or something light.
I don't know if I would put power madd drag ski's on going 150+ though.
It's not much but you can take out the stock steel bumper supports and put some aluminum viper one's in.
Danger Dog said:Thanks LB. I am only making 245. Not bad but not where it should be. The pipes on it now are hacked pretty bad.
