well it is that time of year one slowly starts to re-furbish a used sled and make it into a new one again.This 2002 SRX has 3800 miles on it now,but will be updating things on it like I did on my 2001SXR.
I have the old skid out and the old track.Picked up a 2001 long travelled SXR suspension this weekend.Tore my old skid into pieces,so now I have extra parts.This skid I picked up has had the shocks re-valved for a more comfortable ride.It also comes with max. performance adjustable transfer rods and max. performance marginal small wheel kit up front.The hyfax is graphite and in super condition.I am using the new w-arm I bought last Feb.,since it is still in great condition.I will have it reinforced as well as 2 other w-arms I have that are cracked.They will be re-welded and beefed up.
I am going to paint all pieces blue instead of the standard black from Yamaha.This includes the w-arm.the a-arm,mounting brackets,transfer rods,etc.
Today I went and ordered new bearings for everything on the sled.Also ordered 7.5" rear wheels and 5.375 Polaris sized idlers for all 6 of them.
As most of you already know,I purchased a Predator 1" 6 pitch track a while back already.
I already took the bushings out of the front suspension shock,which were loose already and put in needle bearings in their place,same as the rear shock has.This will make a big difference in the play of the shock.Now the shock can work like it is supposed to and not flop around.Bethaviper has suggested to do this.
I notice on the sled if I put a level on top of the tunnel,I have a 3/8" drop to the right side(chaincase side)But if I lay on the floor and line up the bottom of the heat exchanger on the running board,it is perfectly parallel with the one on the chaincase side.So maybe the tunnel is straight.I started thinking more up front the problem could be.Thinking shocks not adjusted equally,but they are.Trailing arms are perfectly straight to.If I measure off the floor to the top of the trailing arm where it is bolted to the frame,just beside where the footrests are,the distance is 3/8" lower on the right side(chaincase side).Mind you if I grab the arm and pull up on it,the front suspension moves accordingly and I have it level.If I put a level on the front bumper,it shows lower on that side to.So question is,to get the front end level..what do I have to do.Do I remove the front control arms and check to see if there are same lengths for both sides.Would this help you think.Trying to figure how to level the front end.Do I have to block the tunnel right at the point where trailing arm is fastened on the left and torgue the right side up and twist it slightly.Easier said then done I think.Anyone ever dealt with something similar and or have a suggestion for me.It is only 3/8",but since I have the skid out,now it the time I could try something...I don't no.
My suspension setup will look similar to my 2001SXR suspension with the new wheels on.
