The camber on the front end of the SRX is on the positive side.About 1 degree as far as I can see on the angle finder.
Now I will be installing Simmons skis with dual runners.Instructions say to run the camber at 0 camber so ski will sit flat on the 2 runners.The only way to do this without going crazy and adjusting rod(taking off and on many times)many times is to make both upper and lower rods the same length.The factory specs show upper rod length is 460.2mm and the lower rod length is
458.7 mm.Plus or minus 0.5 mm.Since the bottom is shorter,this creates positive camber.Making both rods the same length should bring camber to ZERO.This should be all I should have to do to achieve the 0 camber.
