modsrx said:gone to the dyno ...send me your luck loll
Good luck...can't wait for results!
Have Fun!
true I got what I wanted for clutching. I was always setting my clutch for 8600 so now I guess I will go for 8200-8300 and climb to 8500 will be close anough.sideshowBob said:You now know where to clutch your sled!
Remember talk is just that...the Dyno tells the story for that particular Dyno, operator, corrections ect. With the work you have done, I would say many of us would not see anywhere near the peak power you saw today on that Dyno under the same conditions. The value of the numbers are only really relevant when compared to identical conditions/corrections...on that note I see modsrx was not much different with a well tuned modded sled. Makes you wonder about all those Big HP. Numbers guys throw around doesn't it!
JMO
modsrx said:thnx for the ride and day concept it was fun .....u should learn to speak french now lolll
