Looking good, Nice Parts! keep the pics coming!
staggs65
meat, its a 5hp briggs, its going now purs like a kitten, i think i just had some gunk get lodged in the main circuit, i pressurized the tank and gas came shooting through since then been fine
staggs65
spent today polishing the tunnel
came out pretty good, probably should of had the flash off for the pics
Looks good, keep up the good work
staggs65
didn't have much time on it today, drained the old gas and put it the truck, still had 10 gallons in it. then i changed the pickup filter. what a pita that is. you'd think yamaha would of made the flang and hole for the pickup big enough for the filter, wasted 45 min at least trying to fish it thru the filler hole, finally got it but is there a better way?
YAMAHIZAL700
there is no better way i did the same thing. The tunnel came out very nice
staggs65
thanks could of easily put another few hours in it, but with the amount of stuff left to do i had to call it good enough, and it should only get better each time i touch it upThe tunnel came out very nice
rx1jim
Stagg, the sled is looking very good, nice job!!! It would be worth it to remove the water pump seal. I found on my engine that the washer seal on the impeller failed causing the impeller shaft to rust up badly. Eventually this would have caused the main water pump seal to fail. Worth the time to check it, you'll have to repalce the washer seal.
Jeff im on vacation from Xmas to New Years mind if i swing by and check it out??
staggs65
thanks rx1jim, yeah everything on the engine will be brand new top to bottom, all wearable parts and seals anyway, still have to split the cases and get my crank out, one rod bearing has a dry spot in it so i'm having the crank rebuilt
staggs65
come on over Jake, u still got my # from when I called u, if not just pm me
Looking good.
rx1jim
Stagg, Where can I pick up the supplies I will need to polish the tunnel? I have no experience with polishing and need to pickup the wheels, compound, etc.. I am going to strip and polish the tunnel. Hopefully I can get it as good looking as yours. Thanks!!
staggs65
sears or lowes, if you want to walk in someplace and buy, eastwood.com will get you more for your money but you'll have to wait and pay shipping, i buy alot from them so i joined their buyers club its like 20-30 bucks a year and all you orders are free shipping, i went brown emery, white rouge, then green jewelers rouge and finished with mothers and a black foam pad on a mini buffer, but you could probably skip the green and finish with the mothers by hand and still get excellent results
staggs65
ok the holidays are gone....finally. time to get this project rolling full steam since we have a 4 day storm starting right now that according to reports will be measured in feet not inches. spent the last couple days helping 04rxw10 from the non-smoking side put a sc10III in his sled. it's a 121 skid with custom tip up extensions from CB performance to get back to 136
heres the link to his build with more thorough info on all he did http://www.ty4stroke.com/viewtopic.php?t=70677
my dad has a broken ankle so I have to keep my place and his cleared out during this big dumping. hopefully get some time in between on the sled but otherwise monday i'm diving in and i dont care what else comes up i'm getting this thing done over the next few weeks.
got some more parts in:
blue polyurethane line to replace every line
a racepak avengerIII, doesnt seem to be working right, got to look at it closer
venture radius rods/tie rods from HARNESSRACER
right trailing arm from VIPERKING
might be more, can't remember right now, more to come SOON
Once again THANKS for the help
Looks like you might be riding before me. This past storm I will be cleaning up all week and a storm Friday and Sat.
staggs65
don't know about that, i'm probably 3 weeks away. have you at least tried it around the house yet? let me know how it goes when you doLooks like you might be riding before me.
Nope sled is still sitting on the trailer never touched it after it was loaded the day we finished.
staggs65
got some new progress. reinforced my steering post. i used 6 inches of 1/2 inch pipe. i made a groove down one side with a grinder for the weld seam inside the steering post to ride in, I also turned it down a little until it fit snug inside without having to beat it in. before i put the pipe in i drilled 2 holes all the way through the post, put in pipe and plug welded it
I put the pipe recessed in and also welded the top
I pulled the harness and the vent lines off the post support, sanded it and painted it metallic silver, cleaned and checked the harness and all the connections, replaced the vent lines with blue polyurethane tube, and installed the gas tank back on
cleaned, painted and installed the brake caliper
and the fuel pump
then i started to work on how i'm going to mount the vector seat, hopefully finish that tomorrow
and the fuel pump
