ryanryan
What kind of paint did you use on the chaincase/caliper......it looks goooooooood!
thanksryanryan said:What kind of paint did you use on the chaincase/caliper......it looks goooooooood!
well thats what the trick up my sleeve has to do with, but you already know what that isYou need to it done so we can rip up the trails around here.
not really following you on fuel pump settings? do you mean the oil pump? if so as long as you don't take it apart at the adjuster you should be fine. may need a little tweaking at most, but you'll definitely have to bleed itdo you have to play aorund the the fuel pump settings to get it right again?
soaked it with gunk engine brite gel, scrubbed it with a brush (mine was naaaasty) then pressure washed itwhen you cleaned out the belly pan did you just use a pressure washer and sprayed in there or?
