Allvipedup
Now that's what I like to see....creativity!!!! Very nice work. Looks like you've put a whole lotta elbow grease in that one and it paid off....GOOD JOB!
Derrty_North_Racing
- Sep 16, 2004
Thanks, I do have a ton of time in it, I just stop counting the hours cuz when you hit the trails every second you put into the sled is worth it in the long run. LONG LIVE SX'S
-luke
-luke
very cherry sx,luke long live sx's
brandon_markie
beautiful sled man, very original. Very nice job
Here is my 2001 SX600.Bought it used. Re did a lot of work on it.Put in Rip Saw track 1 1/4". New jackshaft and axle bearings.All shocks re-built.Blue shield.Head gasket mod single layer.Reed spacers and Carbon Fibre Reeds.Replaced bent trailing arms,tightened up front end and added some blue paint.Heated visor connection done also.Replaced broken clutch spring,can't believe I drove it like that at 160 km/hr.Replaced wrong size belt. Put some running board blue lighting strips. Replaced stock headlight bulb with brighter one.She revs out to 9000rpm.Run water wetter in cooling system also.Did silencer bore mod .SHE RUNS GOOD. Don't have a chance to open it up anywhere yet,not much snow around.What speeds are some of you sx600 riders getting,would like to know please.
VmaxSx600
well mine might not be the most custom looking but i do love it! I got 98 picks, Tag Bars, 3" riser, white screens, sprayed shock coils white, plastic skis, thinner headgasket, read notch, bender racing can, thinner weight transfer rod washers, 50/44 helix with 4.5 gram weights in the inner holes, red skid plate, had sportech handgaurds but didnt lilke the way they looked so took em off. hope you like my sled guys... will get pictures once i get my camera back later tonight
boondoctor
You might want to do a search on clutching, 9000 rpm is probably 400 to 500rpm too high without tripple pipes,.I think horsepower peaks at 84 to 8600 rpm on a stock 600.You are loosing power revving that high.Clutch it for the right rpm and she will work great. Turk is another fellow Manitoban who is great with clutching. Nice looking sled though, are those ohlins on the front?bluemonster1 said:Here is my 2001 SX600.Bought it used. Re did a lot of work on it.Put in Rip Saw track 1 1/4". New jackshaft and axle bearings.All shocks re-built.Blue shield.Head gasket mod single layer.Reed spacers and Carbon Fibre Reeds.Replaced bent trailing arms,tightened up front end and added some blue paint.Heated visor connection done also.Replaced broken clutch spring,can't believe I drove it like that at 160 km/hr.Replaced wrong size belt. Put some running board blue lighting strips. Replaced stock headlight bulb with brighter one.She revs out to 9000rpm.Run water wetter in cooling system also.Did silencer bore mod .SHE RUNS GOOD. Don't have a chance to open it up anywhere yet,not much snow around.What speeds are some of you sx600 riders getting,would like to know please.
2001_blue_sxr
- Oct 20, 2005
- New Liskeard, Ontario, Canada
- www.vanducchiracing.com
ah what the hell...
2001 SXR700, mods include: Ripsaw track, AAEN triple pipes, SuperBrights in the headlights, polished A-arms and trailing arms, 2" riser, 21/40 gears w/15wide chain...
to come(of course this is a bigger list lol): head gasket mod, port&polish, "clear" hood, polished tunnel, and everything under the hood that i can get at, viper seat & tail lights(led), hand guards, custom made aluminum skid plate to match the rest of the theme i got goin...
pics, not the greatest, i'm due for good ones once the snow flies...
vmax-sx
VmaxSx600
here she is I got 98 picks, Tag Bars, 3" riser, white screens, sprayed shock coils white, plastic skis, thinner headgasket, read notch, bender racing can, thinner weight transfer rod washers, 50/44 helix with 4.5 gram weights in the inner holes, red skid plate, had sportech handgaurds but didnt lilke the way they looked so took em off. hope you like my sled guys...
VmaxSx600
heres more... all of these pictures where takin before i trimmed the windshield down... ill try to get some recent pics of my sled
VmaxSx600
1 more haha
2001_blue_sxr
- Oct 20, 2005
vmax-sx said:Oh well here's my baby lol all mostly stock ......for now
gotta start somewhere
2000sxr600
is it just me or are 3/4 of the pctures missing?????????
this thread was fro last yr. so the admins probably dumped the pics when they switched to the new server.
Venom
Time to get this thread up and running again. Here's some decals I just put on my windshield. Sled-Headz is our local snowmobile group of riders (www.sled-headz.com).
Cheers.
Cheers.
xt700
- Jan 27, 2006
