Thanks AMATO!!!!
I will be having the case welded!
I definately need a 98 600 twin:
Head
Pistons
Rings
Wrist Pins
Wrist Pin Bearings
Crank Seals
Head Gasket
Base Gasket
Water Pump seal
*possibly Jugs*
If anyone has these parts Please help!!!!
I scraped together $200 today..... thats my budget so far...... not even close yet!!!
Im selling all my other toys if anyone likes RC cars or Paintball guns.....LOL
Head
Pistons
Rings
Wrist Pins
Wrist Pin Bearings
Crank Seals
Head Gasket
Base Gasket
Water Pump seal
*possibly Jugs*
horkn
maxdlx said:I'd say it sucked air throught the JB weld and burnt up. How was the machine represented to you, as mint or as a sled. Maxdlx
ps If it were me I'd make it right, but I'd have told you to begin with
I think that is the case as well.
And i would make it right if it were me that sold it, but then again I would have never sold it as it was without fully disclosing the issues with it.
Actually, I would have fixed it myself, made sure it was perfect ( by getting a different case), and then sold it, stating what I did to it to fix it.
horkn
Mtn-Track said:Way to step up to the plate Pete!![]()
Pete, you are the MAN!
This is why I love TY. And this is why I will probably buy a Yamaha again instead of a Polaris, despite Polaris being so good to me.
TY has proven to be so helpful and informative it is threads/ people like this that just make it so good.
i will call my dealership and get you prices on seals and rings.
silversnow
What kind of Rc stuff do you have Thstorms?
silversnow said:What kind of Rc stuff do you have Thstorms?
I pmed you, I didnt want to sell anything but my sled means alot more to me than any of my other toys!!!!
I just hope you like it as much as I do!!!
amatosrx said:i will call my dealership and get you prices on seals and rings.
this seems stranger than I thought it was going to be....
cylinders measure 74.803mm
pistons measure 74.2188mm
.022" slop between pistons that cant be right....
I am going to need pistons for a 74.8mm bore, can you price the whole kit.... Pistons, rings, bearings, clips, and pins.... Please
PZ 1
- Mar 12, 2005
You should definitely contact the guy who sold it to you and ask him to give you some money back - I would say half of it. As suggested, if he balks, tell him you will post his name here and also take him to small claims court, and then do it if he still refuses.
does anyone know if I have to take the clutch appart to press it off the crank???
I have the crank out of the case and on a press, this is what the clutch still looks like.....
i will check the price on all of these parts and you can check and see if your oil pump is good.thstorms said:this seems stranger than I thought it was going to be....
no leave it together. you will need a puller for the clutch. you can spray some pb blaster in the hole for now to help with the removal. i think that the srx puller is the same as this machine and i have one of these. please check and see if they are the same. what year is your sled.thstorms said:does anyone know if I have to take the clutch appart to press it off the crank???
you'll need a clutch puller.... It kinda looks like the clutch bolt with along non threaded portion in front of the threads(opposite side of the head of the bolt).
i have it mounted in a 12 ton press right now..... I have the crank pointed down, the clutch is on a support, I installed the bolt with an inch of slop.....should I be able to press it straight off????
It would be best to use a clutch puller...
No dont do that!!!!!!!!!
ok...... i stopped......
Someone is ANXIOUS!!!!! I know you want that beast back together..
so back to the other issue..... what size should 600 twin pistons measure???
anybody???
anybody???
