the bearing closer to the counter balance seems to have a little play.... thats the one making a bad whirring noise when it spins....
can you check them by feel or is there another special tool???
the bottom case is completely wasted!!!! marred and pitted like crazy!!!
those are junk cases.
I think the only good part of the lower end might end up being the crank......
the rods have no sign of impact...... I really really think this guy tore the motor down, saw all the signs of a complete piece by piece rebuild on the sled he had just baught and decided to make up a story just to off it.... piston slapped it and hope it holds long enough the buyer lost all his info!!!
if he was trying to make it last long enough why would he use pistons that were too small???? I dont think they would be any cheaper......
what takes a 74.2mm piston????
amatosrx said:those are junk cases.
kinda thought so!!!
what is your schedule like the rest of the week???
as bad as the cases look what is the chance of saving the bearings???
if they have any play in them the are no good. i would get new bearings i do not work tommorow i will be home working on sleds call me 822 0606.thstorms said:as bad as the cases look what is the chance of saving the bearings???
there is play in the bearing on the right in this pic
there is play in the center piece between the 2 rods but the bearings on either side feel good. is the center piece just a spacer??? you can see the 3 pieces im talking about in this pic all the way to the right...
will you get me a price on all the bearings Please!!!
probably the outside bearings on both ends.... the flywheel side might be ok, but im pretty sure the clutch side are scrap!!!!
i will get prices on the bearings to.thstorms said:probably the outside bearings on both ends.... the flywheel side might be ok, but im pretty sure the clutch side are scrap!!!!
well.......... Im doing pretty good.....
I rode for 8-10 hours.....................
I have put in about 12-13 hours working on my sled that "was just rebuild" I sure am glad I babied it!!! lol
Thank You to everyone who has helped so far!!!!!
I will keep you all very well informed!!!
hey i have the puller you need for the clutch. i can get it off for you.
RIVERRUNNER
Again.....from the sidelines this is really cool to watch...wish I could help out!!! Keep us informed!!!!!!!!!!!
with out large bearings it is $631 retail for everthing but my price is $454 dollars. the bearings are 160 dollars a piece. does not include cylinders or head. also will need spark plugs oil and a little patience. i will help you with the rebuild.thstorms said:Thanks AMATO!!!!
I will be having the case welded!
I definately need a 98 600 twin:
Head
Pistons
Rings
Wrist Pins
Wrist Pin Bearings
Crank Seals
Head Gasket
Base Gasket
Water Pump seal
*possibly Jugs*
If anyone has these parts Please help!!!!
I scraped together $200 today..... thats my budget so far...... not even close yet!!!
Im selling all my other toys if anyone likes RC cars or Paintball guns.....LOL
Dnrtheil
Thstorms, I also have a clutch puller that should work along with a puller for the mag. If you want to get them off before you go and see Pete. I also live in Portage, MI near the Austin Lake Public Access.
Derek
derek@signcenter.net
Derek
no1chevyboy
so whos the member that stared this by selling the sled with the junk motor? it would be nice to seperate the awesome good natured ones that are here helping a fellow member!!!!!!!!!!! from the crooks
He wont say,,hell id have it up on a billboard in lights!!!!
ryanryan
no1chevyboy said:so whos the member that stared this by selling the sled with the junk motor? it would be nice to seperate the awesome good natured ones that are here helping a fellow member!!!!!!!!!!! from the crooks
x2, I feel bad that it happened to you, but now imagine how you feel about this situation...would you really want it to happen to someone else?
