Mac said:Zachalyse - Please explain how a synthetic oil destroyed your power valves?
Spinner18 said:not sure what the deal is, but AMSOIL products are absolutely garbage. They have a good marketing department which makes you think its a good oil. Many of our family friends run ice ovals, and we know a few engine builders who build many of the snowcross team's snowmobile engines. The guys who have taken apart motors running amsoil have been junk, the oil doesn't leave a good film in the bottom end, it runs off it and they describe it as too "dry" of an oil. Few of the ice oval guys we know decided to try amsoil after they got a years worth of oil for free... 6 of the 9 engines had oil related problems. They went back to redline, and no issues since.
Best oil out there hands down is REDLINE. non synthetics are much better for your engine, but they will carbon your valves faster. They stick to bearings in the bottom end much better. I would much rather clean my valves more. Also if you have heard of INDY SPECIALTIES who builds the torquemaster bottom ends and has a full warranty on his products, your warranty is VOIDED if you use amsoil or any other synthetic oil. Because non synthetic are proven to do a better job at filming over all internal engine parts.
But if you are set on running synthetic, run redline. The only other people have ran with success is Klotz.
For non-synthetic, the best have been found to be Arctic-Cat Blue, Polaris Gold, and Yamalube(MADE BY CITGO). DO NOT, and I mean DO NOT RUN INJEX, that shit is the purple death to an engine. No Mystic Either please.
That is what I do know from very smart engine saavy tech's.
Zachalyse said:Season 1. Ran Yamalube for the first 1200 miles on my SRX. Cleaned valves. not bad.
Season 2. Switched to Klots, ran 1000. 2 stuck valves and major build up. so, no, technically it didn't destroy them, but sure made a mess of them.
Season 3. Back to Yamalube for 1300 miles this year. cleaned valves much better condition.
Simple trial and error. Did nothing nor did I change anything on the sled. All I did was switch oils for one season. The season on Klogs was costly. I'm sure many will come up with other reasons why my valves were a mess. But rather than spending time researching and resolving, I just switched back to Yamalube. Problem was solved. To each his own.
I will give Klogs one thing. It sure smells good.
mopar1rules said:the only thing i can agree w/you on there, is about the INJEX being garbage.
about the amsoil not leaving a "film" on the bottom end and engine internals, is BULL$hit, cause when i tear my banshee engine down, to change up the porting layout, there is nothing but a golden film of oil on everything. whatever oil buildup there is on the head, wipes right off. not to mention my exh port stays clean too. whoever told you that when they inspected engines that ran amsoil, and they found no oil film on parts, must have inspected the engine w/their eyes closed. i know when it comes to 4-stroke motorcycle oils, amsoil came out on top. i would assume their same great 4-stroke oil technology would be in their 2-stroke stuff.
bluemonster1 said:its a good thing NOSBOY isn't around to read this.He would be having a fit.But I am sure as the wind blows..he will catch drift of it..lol
I am sure as a lot of guys suggested already..maybe how rich or lean you run the oil pump settings is showing different results..no one mentioned BLUE MARBLE OIL.I have used it in my SXR since I got the sled.When I tear open the motor one day..gonna see how the pistons and cyl. walls are doing.I might get a surprise on the wear issue.There is a lot of hype on different oils,each Company competing for the market share.Run what you think works best for your sleds and stick with it.The cost of the oils now with their super properties are starting to get up there to.Maybe WALMART brand will work for most of us..but they are no BIG OIL COMPANY making these outrageous claims.But their prices are GREAT!!!...lol![]()
