good 89A-10 set-up for 1000'???
pro116 said:
Get a tank from wahl bros and put it on the front of your right side running board,thats what I did.Then you will have to drill a small hole in your tunnel for the the hose to run through.I had s pots on my rails where the lube would come out.
you just let gravity force the lube out? I know some guys are using pumps to push the lube to the rails
