super1c
Super Moderator
SRX_700 said:I am also going thru my primary and secondary. Make sure to replace all bushings in both (4 all together) as well as the sliders in the primary. Just because the springs measure to spec, doesn't mean they are not worn out. Replace them (they are cheap) for good measure. How does your rollers, collars and arms look? Do the washers show any wear?
Didnt really get a chance to get too deep into the primary yet, but i will check all that for sure. Thanks chris
super1c
Super Moderator
Well upon further inspection and reading a few posts i found with similar chips im looking at a new primary. Im pretty sure this is not safe? I just need a empty one. All my parts seem good and tight. Weights are in good shape, covers good. Its the little things like this and that exhaust stud that are wearing on my budget and patience. Posted a want ad for one if anyone can help me out. Hears a few pic's. You can see where the screw had its way with a moving clutch. Oh well, better now then having it explode while my daughers riding it. Chris
03viperguy
ugh, sorry to see the setbacks. at least you have a while before snow flies again!
Make sure you go thru both clutches thoroughly. That includes bushings. How many miles are on those clutches?
super1c
Super Moderator
The sleds only got 3000mi on it. I got the good deal because the guy never had the hood up i think. I need a new primary at this point. Secondary is tight, just needs new buttons. Sled is in great shap just neglected over the years. Chris
I believe the primary is still okay and does not need replacing. I would post those pics in the other forum to get other opinions, however.
I agree, I think I would reuse that.SRX_700 said:I believe the primary is still okay and does not need replacing. I would post those pics in the other forum to get other opinions, however.
super1c
Super Moderator
Thanks guys, i posted this in the viper section. That would be great if i could still use this. Chris.
rx1jim
Chris,
My advice is to check, recheck and use only top quality parts in the rebuild on your project. You have several mponths to get the project done and the sledding season is so short. Personally, I would not use that primary clutch since the effect of small imperfections get magnified by the high rotational rpm. I know money is very tight for most of us on here but it is not worth the hassle and danger of having the primary fail while running at speed.
Jim
Jim
super1c
Super Moderator
rx1jim said:Chris,
Jim
You are right and i know better. I will go with my gut on this one and get a new primary. I only need a empty one so it shouldnt be too bad. Thanks chris
03viperguy
can always send it out to be balanced and checked. I know Jaws in vt does it. sure bender or hauck probably could as well
super1c
Super Moderator
Well its good friday and no school so we decided to get the head back on the sled. Wanted to wash it out also but still to cold outside for me. Only 40ish outside. Sprayed the pistons and through the reed ports real good with fogging oil before i closed it up. Couple of pics for ya! Elizabeth learning how to mix coolant and filling it up. Also a good pic of the opticool head torque pattern. It is a little different then stock. Not sure why or if it even matters. Chris
A couple of bucks
super1c said:Also a good pic of the opticool head torque pattern. It is a little different then stock. Not sure why or if it even matters. Chris
What is the physical difference between the stocker and an Opticool?
super1c
Super Moderator
A couple of bucks said:What is the physical difference between the stocker and an Opticool?
No diff in material but the way the holes are cut is a big difference. I have both and i can take a pic to compare if you want. Just had to replace head gasket so went with the opticool. chris
A couple of bucks
super1c said:I have both and i can take a pic to compare if you want. chris
Don't go out of your way. I was just wondering as this headgasket seems to be the norm if replacing one.
super1c
Super Moderator
bluebandit98
big difference
A couple of bucks
Cleaning belly pan
When I cleaned mine out for the first time, it was a chore to say the least. I used these nylon bristle brushes, whatever degreaser I had(probably Simple Green) and ALOOOOOOOT of HOT, HOT, HOT water that came off of the stove. Boiling infact.
The nylon bristle brushes attached to the 12" drill extension that I had for the exhaust can drilling job. Everything was picked up at our local FARM & FLEET.
Cleaned the livin DOG SH!T out of the belly area. Looked new infact.
https://www.farmandfleet.com/s/?keyword=Brush&brand=Dico
super1c said:Got to wait for warm weather to clean the belly of the beast.
super1c
Super Moderator
Thanks for the hot water tip couple of bucks. Really helped with the grease and grimy mess. Boiling water and a little bit of this stuff my wife gave me called "awesome" from the dollar store it came out great. For not removing the engine i cant find hardly any dirt left and grime left. We dont have all are parts yet and we still havent gotten anything painted but we can start putting a few things back together now. Chris
wow. Looking great. I definitely will be picking up an Opticool for my viper this year after seeing your pics. Did you manage to find a primary? I thought I spotted one on fleabay yesterday. Ill see if I can find a link.
