burnoutink
Nice, Air Shox are the way to go!!!
musselman
Test fitted one of the trailing arms, looks great on there. The geometry is much better than the stock arms, here are some pictures
I also got one of the footrests removed, will be easy cleaning that area now
SRX500kid
i wish i could get fox floats a the way around on my sled but they are wicked expensive!!!
super1c
Super Moderator
Looks great. I think your going to have to drill out all those structural rivets from the trailing arm mount then redo them for the viper foot wells as some of the rivets go on top of the well to hold it. Or you could mod your wells and make it work. I have the part number from yamaha to reorder those exact rivets if you go the drill method. Got mine from portyamaha Expecting them later this week to finnish my running board mishap!!
musselman
Yah I'm going to pull those off anyways so I can fix my running board crack issue. I actually have a bunch left over from when I last ordered them from Ding. Hopefully I have enough, if not I will let you know.
musselman
I also managed to wreck my steering hoop (frame around the gas tank). I was removing the bolts that hold the footrest on and the threaded inserts just spun inside. I figured it was best to remove them instead of having a loose frame. So now I need to look for a steering support frame.
staggs65
pretty sure I've got a steering loop
musselman
PM sentstaggs65 said:pretty sure I've got a steering loop
Iknow this is off topic, but how many lbs of preasure do you run in your front floats shocks. just put a pair on my 2000 SRX.
musselman
Last year I ran around 55 psi, ride height was fairly high but the ride was nice. I think I will try the same next year. These are floats from a firecat though so they might be a little different.SRXAPEX said:Iknow this is off topic, but how many lbs of preasure do you run in your front floats shocks. just put a pair on my 2000 SRX.
I put fox float 2 for apex and vector models. they are 16.5 inches long from center to crenter. How long were the firecat shocks?
musselman
The firecat shocks are 17.75" long and they are the original float's.
musselman
Just thought I would give an update on the sled;
I sent my trailing arms out for powder coating, I chose brilliant white for the colour. I also decided that I should get my pipes ceramic coated. I am going to try afterburner performance coatings in Bradford, looks like they do nice work and close by too. I am going to get the polished coating that looks like chrome, can't beat that, then polish the heat shields to match.
I will get pictures of the trailing arms when they are complete and some updates on the sled soon.
red rider
Musselman your sled looks awesome. Just wondering how you like the powertek front end and what the advantage is? I went to their website and they don't offer it anymore. Any ideas where I can get one?
musselman
Thanks! The power rak is awesome, at 44 inches wide it absolutely rails around corners. It also reduced the steering effort and eliminated any play throughout the system. I picked up mine used so I think that's the only way you could get them now, or you could always build your own.red rider said:Musselman your sled looks awesome. Just wondering how you like the powertek front end and what the advantage is? I went to their website and they don't offer it anymore. Any ideas where I can get one?
musselman
Removed then engine on the weekend and took apart the steering rack and greased the bushings, it's amazing how smooth and tight this steering is. I also got the bushings in my new trailing arms, all I need now is some grease fittings for them. While the engine is out I need to install my RSI extended oil cable as well. Pictures will follow tonight.
musselman
Here are some pictures,
Rack steering assembled and greased
Some pictures of the trailing arms with bushings installed
Do you think this crank seal is leaking????
super1c
Super Moderator
Man those trailing arms are bad a**! They are going to look sweet!
Hard to tell if the crank seal has residual grease from the seal lip when the last one was installed or if it is actually leaking.
If it were my sled and it doesn't have many miles since last seal was installed, I would clean it up and occasionally check it to see if more oil shows up.
Although...since the engine is out anyway...it would be much easier and give you peace of mind to put a new one in now...
Let us know what you do.
Bob
Sleds looking great!
Bob
musselman
Thanks guys, yah I just installed these seals last year so they only have 3500 km on them. I'll just clean it up and keep an eye on it, don't really want to do an engine tear down at this point.
