staggs65
did you get the steering arm figured out?
musselman
Nope, nothing yet. I'm waiting to see if the snocorss replicas are going to be produced in time and at a somewhat reasonable cost. If they don't work out then I may have to run my stock trailing arms, which would be a huge waste but what can you do.
I have the spindles, they will work. apex spindles with viper tops.
for others, if you want to build a power rack, it is just parts from mid to late 90s polaris. This is what it is based off of. It will allow the use of long shocks like he is using. if he didn't use a power rack. his tie rods would want to bend over the bottom of the hole they run through when he unloaded the sleds suspension.
Looks cool, must have a foot of travel up front. Like the running boards.
musselman
That's great infoBETHEVIPER said:I have the spindles, they will work. apex spindles with viper tops.
musselman
Here are some pics of the rear suspension mock up:
yami1
looks like you got that front end figureded out?? what did you do
chris700readhead
That looks sweet
i sent him apex spindles with viper arms,
musselman
Those are older pictures (about 3 weeks ago) I just got the apex spindles and viper tops on Monday and installed them last night and everything worked out great. The front end is very tight now, I like how you can snug up the spindle with the viper steering arm and not have all the up and down slop the stock one has. I will get some pictures tonight of the front end.
I also finished my footrests and running boards and dropped the engine in as well. The only big thing left to do is install and wire the viper gauge, other than that it is getting pretty close.
super1c
Super Moderator
Nice cant wait for pic's. Was wondering how you made out on the gague pod mod.
SXvmax700
i wish my garage floor was that clean.
its black even after ive cleaned it.
musselman
If I let it get dirty I would be in big trouble lol, so I try my best to keep it clean and catch all fluids before they get to the floor. Doesn't always work though.
musselman
Here are some updated pictures, front end is assembled but needs to be aligned still. Also started cleaning the power valves, wow they are dirty, I still haven't found a good way to clean them, time for some searching.
super1c
Super Moderator
Man is that thing bad a$$. Looking great.
FJViper
Nice looking sled. Great work all around. Man, I just love the look of those trailing arms!
pv. new razor blades to shave off the bulk and carb cleaner and soft brush or dish rag to clean the rest.
I am curious, knowing how messed up bump steer is on a pro action, could you do a toe measurement compressed, center and lifted? curious how much better the unequal length arms make the sled.
yamaha1973
the Yamaha decarbonizer works pretty good too... its strong stuff, do it in a well ventilated area
musselman
Got the valves done, the carbon was really baked on there and hard as a rock. With a new razor blade though it came off fairly easily, thanks for the tips guys. Here are some pics of how dirty they were:
SRXSRULE2
I'd love to see this beast in its new form this winter..
Cooper0809
That is great work you've done to that sled. I cant wait to rip my sled apart. I'll probably keep mine all stock though...haven't decided yet.
Nice sled!!!
Nice sled!!!
