SSR 440 oval clone (440x)
Yamaha Nutz
southeast Wi
SSR 440 oval clone (440x) now w/race action video link
sled started out as a 87 indy trail add one 78 SSR hood and one very custom 79 mod srx 440 motor and set of Aaen pipes keep in on this the sled is coming along nice and should be done in a month or so we will start at the beginning with the pics
aaen pipes reworked to fit the sled
Cool Mike!!!!!!
I have to get up and see this one. If it turns out as good as your other builds it will be Killer.
opsled
opsled i finally found a use for that special Aaen srx motor i am around most weekends but things are pretty busy here in july just give a jingle before you want to stop up .........................it has been a while the Kalamazoo fuelie gpx is going to be ridden finally she is set up and will be ready for princeton to hopefully beat up on the delaughter sleds........................... more pics to come plus i will throw in a few of the other sleds all the racers go a frame up this spring
Nutz
75 gpx SS 440 oval racer all freshend up
the MUTT 2010 ovation phazer exciter combo doing well as it should
the original 75 gpx 433 850 original miles never polished not new parts only thing redon was the hood
80 ss 440 superstock fan oval racer getting the finishing touches
hood for my 74 gpx 338 oval racer took a weekend worth of work to paint this hood and i was leaning tward the marbleizing with the ssr hood
the kalamazoo fuelie mod
the trail rider EX 440's
the 76 SRX 440 retro clone with hand carved seat that i think looks pretty close to original
http://i191.photobucket.com/albums/z64/mpsalvage1/068.jpg[/IMG]
Well to keep you guys entertained while the project is coming along ..................should have the motor in and front suspension done tonight here are some more pics of the GPX 338 and the 78 srx
433 oval racer
Enjoy
thanks for the comments guys..................... things are coming slow right now too much work at the DPW.............. but it is back on its feet again front suspension back in place and jackshaft in next step is to get the motor mounted up and center to center and offset set then we can start on the clutch guard just so you guys know (being a yamaha site) polaris center to center is 12'' I chose to go with the 10.56'' of the yamaha center to center and i will be running the phazer II belts 87X and if things don't work right with the clutching i will go back to the srx primary (which i know inside and out) and with a 70's polaris secondary and run the 89X belt (narrower) so here are some more pics
Motor is in and snugged down just a little bit of alignment needed yet plan is to ge the exhaust brakects made tonight and the exhaust and blasted and painted up more pics to come
