dsc577
yea,hope ya find some but i think good ones are scooped up and spendy,i have one thats dented so i drilled a hole on the backside,pounded it out and threw my old bender covers on it,ill keep lookin,never know
saw a clever man on swedish snowmobile forum that put ordinary downspouts over the shocktowers and painted them silver. It locked like stock, a cheap way to fix dented and chabby towers. Might do that if i can´t find a set of nice ones for a descent cost
This might help you WWW.excitersx.com
dsc577
yea i did something like that to,my buddies aaen pipe busted in two,took off a cover and slipped the two halves back together!didnt even leak,stopped at a gas station and got a few hose clamps,good to go,pretty funny huh
prankster said:Lasse,
Let me know if you hear someone parting or selling Exciter or V-Max stuff for decent prices up where u live.
I will have my eyes open.stanage
Just FYI - http://www.schmidtbrosmotorsports.com/ can rebuild your struts, re-valve them to your weight, and can straighten out and remove any dents in your cans. They worked wonders on my cans, and re-valved my struts for 200lbs. Makes the hugest difference in ride handling, amd makes the front end feel smoother than a new sled!
thanx stanage, but the shipping prizes would make those towers damn expensive....... i try to find some here or make that quick fix. Contacted a motive painter today btw
Will try to make my hood look really bad....til next year
kev45sk8
hey guys a got a question : did a phazer hood will fit on a exciter ??
Vmax540
Read here what Opsled wrote about Comet 108's and seems to me to be the same with the Exciter ?
http://www.vintagevmax.com/vvforum3/viewtopic.php?t=23
stanage
Vmax540 said:Read here what Opsled wrote about Comet 108's and seems to me to be the same with the Exciter ?
That explains A LOT!!!! I have one of those machined helix's. It has rough ramps, but Im sure if I clean them up and smooth out the rough parts I can get more performance out of my 108 setup. Thanks for the info!!
Ok, time to give the old ex some better brakes
Is there anyone out there who´s got a good template to a bracket for mixing the exciter chaincase with a vmax 700 or srx caliper?
Is there anyone out there who´s got a good template to a bracket for mixing the exciter chaincase with a vmax 700 or srx caliper?dsc577
was tinting my truck taillights and...
dsc577
think i need a blue bumper cover and a snowflap!
It looks really nice! I agree a blue flap would be perfect
i´m thinking of changing my seat to one from a rx1....what do u think? Could be really cool if i make it fit.
dsc577
could be,i really dont know what they look like but i am sure you could make it work,newer seats have much better padding
Finally! I got a hold on some dual psi:s, been looking a long time for a couple of these pipes
Now i really need another clutch setup..I was thinking 10 al weights and a red comet spring, (can´t find a polaris dark-blue and white) What Do u guys think about that? I would. like the engagement pretty smooth and it must be suitable for powder...
I have an 88 that I race in vintage ovals, does anyone know how to go about lowering the front suspension on this sled?
opsled
lcummings said:I have an 88 that I race in vintage ovals, does anyone know how to go about lowering the front suspension on this sled?
They call them lowering tubes. If you take the cans off the struts on a TSS sled you will see a kind of stepped washer at the bottom of the spring. The step is about 3/4" or so depending on the model. The OD on the washer is where the bottom of the spring rides. The ID on this washer is where the top of the strut rides. Without the ID the strut would go right up inside the spring.
A lowering tube is nothing more than this same stepped washer with a greater distance between the OD and ID lips. You can make your own lowering tubes by cutting this washer and welding in more tubing to increase the distance between the OD and ID lips. 1" added lowers you 1 ". 2" added lowers you 2", etc.
Once you look at it it is a simple deal.
opsled
87YAMAHA-570
Can some one tell me the stock top chain case sprocket is and if i go up one or two teeth will it make it bring the front up more
