Rustman
take this however you wish but if it were me id be running bigger pilots, i have an 800 with bender quads, no porting and I'm gonna start with 52.5's with fuel screws at minimum 2.5 turns out to start.
it will not cured the problem in midrange ...............but for sure it could be good
YAMMIEGOD3:16
UP YOUR MAINS AND CHANGE NEEDLE/ CLIP POSITION. 3:16 (yammie tony)modsrx said:it will not cured the problem in midrange ...............but for sure it could be good
YAMMIEGOD3:16 said:UP YOUR MAINS AND CHANGE NEEDLE/ CLIP POSITION. 3:16 (yammie tony)
running 160 in main ...main will not cured the problem in midrange will see tonight if moving the clip to the max spot will cured if not will change needle for smaller size
YAMMIEGOD3:16
IN 1987, NEW EXCITER HAD SAME PROBLEM, BURNING DOWN IN MID. YAMAHA WORKED WITH PSI FOR RICHER NEEDLE JETS. 1988 PROBLEM SOLVED. 3:16 (yammie tony)
hope yamaha did some smaller needle
toydoc
They have a factory clear washer under the clip. Sounds like the washer maybe missing.
If you can't get rid of the mid range lean spot with the nedles and you don't have an air leak somewhere you could try installing larger needle jets.
The stock vmax4 800s had 499 series Q-4 needle jets and the 700 SRXs have 499 series Q-6 needle jets so you could install 4 SRX needle jets and see if it improves your lean condition.
As a side note:
I have my 96 VMAX4 set up basically the same as this and have close to 6000 trouble free miles on it since the porting and Aaen pipe installation and have NOT had to richen up my needle jets beyond Q-4s.
Bob
As a side note:
Bob
sideshowBob said:If you can't get rid of the mid range lean spot with the nedles and you don't have an air leak somewhere you could try installing larger needle jets.
As a side note:
Bob
i beleive it .......
that sled seem not to have any dc current anywhere so the o2 gauge doesnt work like it should ....getting out of idea with that monster
meeeooooooooow!!!modsrx said:i beleive it .......![]()
...meuhhhhhhhhhhhh meuhhhhhhhhhh bahhhhhhhhhh bahhhhhhhhh
stupid sled start to turn me crazy lollll
big thnx to SIDESHOWBOB ..give uss a huge help to make that vmax4 back in business.....
the monster is dead again
mod you bring bad luck with you...
yeah i guess so lolll... i chew up a another pwr valve yesterday lollll..remove head take the power valve out put the head back didnt put nothing back there and sled work like hells loll..what the hell those power valve do lolll..didnt see no difference at all loll
low end maybe get a bog without PV's but at wot no difference..maybe should remove mine and always ride WOT>>yeah!!
bluemonster1 said:low end maybe get a bog without PV's but at wot no difference..maybe should remove mine and always ride WOT>>yeah!!
for 1 pv i didnt see no difference at all ...i will put a use one and screw it open tired of that problem
