What Did You Do To Your Sled Today???
not a thing..its cold out and I won't even go outside lately.Kinda waiting for Spring again as I am outside everyday working on my yard.Winters I am inside doing nothing a lot..starting to get boring.And when it gets cold out,I don't even think or care about sleding to tell you the truth.
cleaned carbs, bled cooling system, alligned and tensioned tracks, plugs, greased every fitting. (every thing x2)
Sled Fix
Well big weekend for the sleds. NO SNOW again so I worked on my 99 Phazer project. Mr Viper ported jugs installed, replaced the butterfly carbs with XTC flat-slides, painted the Hauck pipe, installed extended oil cable and replaced throttle block. Sled would only give me 6 grand ? Beat head against wall for hour wondering WTF. Checked primary, secondary, carbs WTH ? Removed the top of the air box and wholla 7500 ! Drilled 1" hole in top of air-box and now its ready for snow. Dent in forehead still hurts.
Buddy's SRX broke a chain last year so into that I went, found the chain came around and snapped the jack-shaft clean off ! Hole in the case and top gear are all smoked. Parts available but not till next weekend will that SRX be ready. Little ice fishing Sunday, DAMN COLD out there but better than sitting and looking at the sleds.
A couple of bucks said:
How'd that turn out for ya.
got 1.5' of snow and trails where open this weekend!
fixed taillight on dad's venture and installed rock's hot hands for the passenger. dropped apex at dealer for 1st service.
Not today, but just catchin up.
Bought it, drooled on it, waxed it. Then got busy.
Pulled the skid and serviced accordingly, new bearings front to back, cleaned carbs, serviced clutches, pulled checked and wrapped wiring harness, cut down the too long studs, shimmed the skis, new exhaust donuts, and of course new fluids.
Today it sits as a frozen fudgesicle. Time to go at it with a rubber mallet then off to the car wash. Also pick up a carbide to replace the one I tore off yesterday, fill tank, ride. ;)!
Picked it up. blew up my Sxr 2 weeks ago that I put a 141 in so I now have an 02 viper with 3000 miles ripped her around a little I'm impressed so far
