orchie18
Ok, we'll who ever installed the 38mm carbs must be blind. Here's what it currently has for jetting, try not to laugh.
1 carb had a 200 main, the other side had a 150. Huh?
The pilots are 350 on both
The needles are set at the middle position spacer on top and bottom
The air screws are 2 turns out.
They are definatly 38mm carbs, I measured. So can some one get me started on a base line jetting. Cause clearly this ain't even close. We are at sea level and average -10 degree celcious or 14 degrees farenheight for my south of the border friends.
