Yamaha Nutz
well porting is all done (sorry no more pics of the cylinders and the ports).....new pistons and rings and cylinders are now on the motor ....also made up the custom thermostat housing to clear the hood and act as a water restrictor ......built a new primary and have a initial set-up in it that I am sure will need some fine tuning .....skis are built just have to blast and paint them ......custom seat is recovered (same cover) had to put different wood and reshape a bit since it will be a drag sled .....sway bar covers installed ..........it will be close but I might have it out for a show on Saturday ....not running but close should be up and running and making its first passes on the test track in the next few weeks .....
