YooperWoods
Well for now I've got bigger things to worry about, it just keeps getting better and better. Popped the clutch off tonight, the water trick worked awesome btw and if you've never removed a clutch this way it is so easy. Anyways lots of spooge around the pto crank seal and I thought well there's why the pto piston melted down, glad I split it. Once I got the crank out I felt all the bearings and the pto side bearings did not feel good. Take a good look below and notice the piece of metal between the two. Looks like the cage in the outer bearing let go, there are lots of pieces of it in there. Bummer, now I've either got to replace those bearings or find a good crank.
