Cooper0809
Try posting in the wanted section...
			Good luck my friend, hope it all works out!
			Cooper0809
Thanks bud! Going to be quite the drive...
			Cooper0809
Wow! What a beauty day for a drive! Honestly I just wanted to keep driving further north for the hell of it! Anyways, 8hrs driving, 900km and $150 in fuel later I finally brought the old girl home...needs lots of work getting it cleaned up! Noticed both tracks are screwed so I can't even sell those. Skids are in pretty good shape. Working sled even has a kimpex gold rear skid shock, so I'll be putting that on the enticer...if it fits.
So I drove to Verner, very top of lake nippissing.
							Cooper0809
Cooper0809
Cooper0809
I'm still looking for a skid, and I'm thinking I'll make a stubby seat from the old seat foam with new vinyl. I need a new carb boot, battery, speedo cover and bearing holder as they are worn right through. The bearing is completely gone. I dont know how it even drove. The wheels in the skid are so wobbly I'm suprised they haven't fallen off yet. This whole sled has been neglected for years! I'm honestly afraid of what I'm going to find next.
Cooper0809
What the hell, might as well pull the engine and clean things up and look everything over...got lots of time!
			Cooper0809
YooperWoods
Lookin good Coop, hope you don't find all the crap I did when I built my Phazer!
Cooper0809
Thanks Yooper! It all went well and looks to be ok, I'm not diggin into the engine tho, gona run it until she blows and in the meantime do a complete rebuild on the spare. I honestly thought it was going to be pretty bad, but it looks ok...just really dirty and I can't stand a dirty sled! Lots of time to clean it up before the snow starts flyin again.
Do you know how to take apart a primary & secondary? I wouldn't mind rebuilding them if I can... Just don't want a spring or something to fly up at me! Lol. Any tips or tricks?
RON HYDRAULIC YAM
I have the books at home from leaf spring VK540 and pogo VK540...  but have never worked on the clutch... did have someone check it over
while the engine was out and replace the outer bushing . Always need some special tool .....
Before I got mine , someone had blown out both the oil pump cover seal (was missing from sled) and the PTO crank seal probably with ether ...
It ran well and I just used it for tugging a small ski track setter in back yard / bush. It never liked to sit and idle but pulled like a horse ... Finally one Sat
morning I decided to check the plugs ... the PTO side was packed with Almn .. The darn thing still ran and had been like that for probably 3 winters., just
eating away inside ... about a 3/16 groove from pin up the wall , all the skirts packed into the ports. etc... even the mag side seal had been on fire at some
point and drooped .. Crank was packed with filings ,,.... I should have known better and checked it when I brought it home ...
After saying all that .... check that engine ..... !!!
I had trouble finding a donor engine and ended up with one marked SR540 ... bigger reed valves etc and had crank rebuilt on it and new pistons and seals..
It now even idles ...
You must be an hour west of me judging by the travel distance.. i'm near Newmarket ont
Ron
Ron
Cooper0809
Yes, new market is exactly 1 hr away from where I live. I'm in fergus.
I did a compression test before I bought it. Within 5psi of one another. Plugs look good too. Like I say, I'm going to be rebuilding the spare engine. But I'd like to rebuild these clutches and get them cleaned up. I could easily use them the way they are, but for the price to rebuild them Id like to do it...can't be too expensive!
These engines are tough as nails! Plenty of power to turn a 144"! Lol
Cooper0809
Cooper0809
Nytro seats are nice. Not so wide, comfy and allows you to jump from side to side easier for those deep snow "action" moves!
			Cooper0809
Ya this one is like new! It needs cleaned up a bit...just has a bit of dust on it. I like the all black with the red stitching.
That seat combined with that skid is Gona be quite the comfy ride!
Cooper0809
Went and picked up the 31T & 17T gears and chain from a guy thismorning. Got the set for $25!!! They came out of a 540 SRV. XLV bottom gear is a 29T and top is 17T. Hopefully I'm done with driving to the ends of the earth for parts! I still need to clean the engine then I can put that back in and focus on putting it all together.
			Cooper0809
Got a bit more done today! Painted the pipe flat black, engine is back in, bars and new cables are on.
