Viper shocks are. From an srx you can only use the center shock, not the rear(most), it's shorter.
Vincent
Well-known member
https://www.kimpex.com/en-ca/produc...pension-shock?sku=301528&keyword=Yamaha shock
Found this, it matches my center shock numbers pretty well. Don't understand why Royale Distributing doesn't carry them. Weird. Seems like they would work and the price is reasonable aspecially with free shipping.
Problem is when I tried to buy one off the website a message would always pop up saying they don't ship to my area. Double weird!
I ordered the rear shock ( also Kimpex gas shock) from Royale D. 113 $ is a great price and will probably make a world of difference from the original 17 year old one!
Vincent, my father has an 05 sx venture that we put a set of olins my brother had on his 02 sx viper. they bolted right in but I should have used the rear venture spring as I had to turn it way up on the olins spring to make it work. the front shock from a rx sled will work as well and I know the 04/05 war ones are rebuildable. his stock oil shocks where toast before we hit 3000km.
Vincent
Well-known member
Thanks guys for the responses. Very good information.
Just finished up all the rear skid inspection, repairs, new sliders and full lube up,. More surprises then expected but it's all done and ready to go back in. Minus my two new Kimpex gas shocks witch have been ordered and are on their way.
Next, clutch overhauls!
Vincent
Well-known member
Also started looking for a stock RX-1 or Apex helix (51-43). So if anyone has one and doesn't need it, send me a message.
Vincent
Well-known member
Did a Kwik check of my chaincase today. All seems well there. Closed her up, reset the chain tension, and filled it with fresh full synthetic gear lube.
Also ordered all my clutch bushings from yamaha. Yamaha offers a Primary clutch maintenance Kit. Includes all new bushings, rollers etc..... all the stuff for the secondary clutch like bushings, plastic slider shoes etc... are individualy ordered. No springs or weights on this order.
Total came to 390$ with taxes! Ouch! Plus my two Kimpex shocks, and new sliders equals 720$ with taxes double Ouch!
If you want to play you have to be willing to pay.....
Should have just bought the dupont sliders. I did for my vt 500. I hope they are as good as they say.
A couple of bucks
Vincent
Well-known member
You are really REALLY rolling the dice w/ that chain. It is too long. Probably 2 links. How many teeth top & bottom are you running?
Here is a gearing chart that tells you ratio and links. 1 pin = 1 link.
It's stock 22 / 39 gearing with the 70L chain. The arc looks identical to the images in my Clymer shop manual
Though I'm sure the chain is a bit worn and a new one would offer more peice of mind .
A couple of bucks
It is definitely stretched and has been shock loaded too many times. The more bend that the tensioner has to take-up, the more power is lost.
shaggyzr2
It is definitely stretched and has been shock loaded too many times. The more bend that the tensioner has to take-up, the power power is lost.
Not only do you lose power but with too much bend in the chain it could snap. I had a chain snap on my sled because the previous owner had too long of a chain in it, chain snapped, blew apart the chain case and damaged the gears.
Vincent
Well-known member
Fair enough. I'll start looking around for a new chain. Thanks
So I'm looking for a 70 link, 13 plate silent chain correct?
Royal D has them for a reasonable 89$!
Vincent
Well-known member
Went ahead and ordered a new chain. Thanks for the heads up guys!
Vincent
Well-known member
A couple of bucks
When ya get that new chain on, post a picture. Just so everyone can see the difference.
Vincent
Well-known member
Here you go.
First pic. Top new chain, bottom old chain.
Second pic, old chain.
Third pic, new chain.
The arch improved, but only slightly
Vincent
Well-known member
Skid is assembled and all freshened up, complet with two new Kimpex gas shocks! Took 70 min to get it back in alone. Actually went really well compared to removing it.
Also received all my new clutch rollers and bushings etc....
Wow, when I did mine, it took 70 minutes to get out and 6 hours to install.
Vincent
Well-known member
Decided to change the bearing in the chaincase cover, and the bearing in the chain tension idler. Both were ok but original. The new ones feel a bit tighter. They were both a pain in the a$$ to replace.
Also took on the challenge of disassembling my clutchs, splitting the primary, removing every slider, roller, plastic washer, weight bushing, and main bushings. Replacing everything with all new yamaha supplies.
(Very expensive!)
Again, what a Pain in the A$$ that was! Every bushing were excessively tight and difficult to deal with without the proper tools to remove and install them. But after hours of tedious work I manage to replace them all without damage. The clutch sheaves, weights, rollers, sliders etc... All have zero slop and move much smoother then previously. Big difference!
Can wait to enjoy the fruits of my labour!
(Very expensive!)
Vincent,
You inspired me. I drug my sled out of storage and fill the tank with fresh gas. It started up without too much problem. I did my skid and shocks last year and only ran less than a 1/2 tank of gas, so I'm good for this year. I do have my Boss seat and risers to install.
