Fogging 3 cylinders at once
unchained said:
I agree with using ATF 100%. Gary, instead of pumping raw ATF into the fuel system, what about pre mixing the last 3 gallons in the tank at about 20:1 and run the sled for 30 min or so untill it gets thouroughly through and coats everything...
This is pretty much my procedure as well. Except mine is probably @ 15:1. Let it get hot and smokin really good. I then take a small (1 gallon) Hudson sprayer set on a fan pattern, filled w/ ATF , then spray it into the slush box and down her throat till it dies.
