where did you get the track from,I don't think I have seen it at Royal Dist.
opps..just found it in their catologue for $399..cool..
							orchie18
YAMMIEGOD3:16 said:No My Cap Locks Ain,t Stuck. Its Me Talking To You Guys From Yamaha Heaven. 3:16 Rotflmao.
Hmmm...i just thought you were mad at me...
bluewho
Its all good untill your shadow starts beating you..yikes!
that is why I ride on cloudy days..no shadow issues..
YAMMIEGOD3:16
ME MAD ? NEVER !!!!!!!!! 3:16 (yammie tony)
			orchie18
good nobody likes a vengeful god
			Jr.SRXpilot
Hey guys,
Trying to send my SRX into orbit....using the 8DN20 now and pulling 103 with the gps....pulls like hell, and then dies at the top.
I am buying the 8BU-10s and want to dial them in properly.
if I put the 3.6 rivet in the bottom and drill it out, what procedure do i use to get it down to .85????...like what is the size of drill bit...how many smashes with the hammer to flatten it etc?...once it's in, you cant weight it any more?
YAMMIEGOD3:16
ALL MY YEARS HERE I FINALLY AM STUMPED. '' HOW MANY SMASHES WITH THE HAMMER TO FLATTEN IT ''. wow !!! 3:16 (YAMMIE TONY)
			mopar1rules
YAMMIEGOD3:16 said:ALL MY YEARS HERE I FINALLY AM STUMPED. '' HOW MANY SMASHES WITH THE HAMMER TO FLATTEN IT ''. wow !!! 3:16 (YAMMIE TONY)
  ahhhhhh, too funny.Why not just buy the .8 rivet? as far as installing the rivets if you are going to use a hammer to flatten them out then the amount you do is kinda up to you they just need to been peened over enough so they don't fall out. MTX makes a nice tool for installing and removing rivets if you are going to be doing it alot. Costs about $60Jr.SRXpilot said:Hey guys,
orchie18
I would load them up with 4.5gms and then go go down if its to much weight. Im no expert by any means. But loading mine up with the 50/38 helix was the right combo. took it out tonight and wow...thats all i can say. Hit 110 on the dreamometer in just over 1000ft.
			Use bolts washers and jam nut,,, screw em out instead of yourself..........still don't get the drill and pound thing........ try for tuning,, and then pound,, once you got it down..........
the bolt idea sounds good..could you post pics of the bolts you use and the sizes..
			They are 10-32 button head machine screws, washers, and jam nuts (thin nut),, use a gram scale to get desired weight........take the gram scale to the hardware store with you,,, as there can be a difference from one bolt to the next...........
			Corey9965
Corey9965
orchie18
A former yamaha racer asked me what size rollers i had in my clutch i was half snapped when i talked to him and dont really remeber what he was talking about but. What effect will different sizes rollers have on a set up?
			YAMMIEGOD3:16
BELT SQUEEZE. VERY INPORTANT. THATS WHERE HOT CLUTCH SHEAVES PROBLEMS START. 3:16 (yammie tony)
			orchie18
YAMMIEGOD3:16 said:BELT SQUEEZE. VERY INPORTANT. THATS WHERE HOT CLUTCH SHEAVES PROBLEMS START. 3:16 (yammie tony)
Any suggestion on a roller for my current set up or is kinda changed out based on how much belt slippage and heat is occuring in the setup.
smaller rollers will squeeze your belt more..Turk was recomending that to me when using HC's to go 14.5 rollers..
