stanage
prankster said:Did a little maintainence work while i´m waiting for my shocks to arrive. Found a new shorter seat which was in very good shape.
Did a little polish and cleaned the carburettors and changed all the hoses too.Wanted to know why the throtle hangs up every now and then. the wire and throttle adjustment bolts were really worn so i ordered a new one. ! Also ordered a really good thing: Ice scratchers! (For cooling of the slides)
I Also checked the entire cooling system just to make sure everything works perfectly when i leave the garage. Finally found some shocks on ebay, hopefully i get them real soon![]()
FYI, the steering column likes to wear our the filter on the carb that its closest to, letting dust get in. I installed a Pan filter instead, with a metal lip, and it can rotate out of the way... otherwise perhaps one of those filters with the offset mount would be good on that side.
