YAMMIEGOD3:16
23/37. I AM GIVING YA 800 COMBO HERE. 3:16 (yammie tony)
is it possible to run a pink secondary spring with a aggresive helix in those vmax 4 ......green and grey the secondary shift wayyyyyyyyyyyyy to fast with a 50-43
YAMMIEGOD3:16
WHICH PINK SPRING ? 3:16 (yammie tony)
90508-60012 ----pink yamaha factory secondary ...green and silver doesnt hold the clutch at all ....u move 50 feet and its already shift
mod it seems like any motor you run you blow them up..what gives...lol
You like to go KABOOM or what????
bluemonster1 said:mod it seems like any motor you run you blow them up..what gives...lol
my sled work awsome blue ..told my friend to put bigger jet in it but he got a hard head ....8bu-10 work good need to get a bit more top end out of it ....he got a overheating problem too so............ will see at the end of the week
lucky you then,,lol....here SRX is put to sleep for another year..8bu-10's are getting a rest to....
YAMMIEGOD3:16
THAT THE 4 STROKE SPRING THAT COMES IN A APPEX. 3:16 (yammie tony)
YAMMIEGOD3:16 said:THAT THE 4 STROKE SPRING THAT COMES IN A APPEX. 3:16 (yammie tony)
possible don't know tony .....will try almost a stock helix and see ...the beast overshift wayyyyyyyyyy to fast ....
bluemonster1 said:lucky you then,,lol....here SRX is put to sleep for another year..8bu-10's are getting a rest to....![]()
why blue ???? they perform like the 8dn-20 and they seem to have a pretty good backshift
cause there is no snow to test them they need a rest as well...modsrx said:why blue ???? they perform like the 8dn-20 and they seem to have a pretty good backshift
yeah sucks ...here we got the minimum of it ........its gonna be the worst winter i ever seen
YAMMIEGOD3:16
i,ll check. if it is , that spring a bear. DON,T WIND IT PAST 70 DEGREE. 3:16 (yammie tony)
YAMMIEGOD3:16 said:i,ll check. if it is , that spring a bear. DON,T WIND IT PAST 70 DEGREE. 3:16 (yammie tony)
i never wind spring more than 80 or less than 60 ......but to run those helix will need something with alots more pressure than the stock one
YAMMIEGOD3:16
modsrx said:i never wind spring more than 80 or less than 60 ......but to run those helix will need something with alots more pressure than the stock one
we got the motor all back together and did some test with the new o2 sensor in a pipe .....sled is running wayyyyyyyyyyy to lean for midrange .....who think we should put back all the air box original not empty .....
Rustman
so it was a mid range burndown?
for sure it didnt help .....midrange suppose to be around 13.5 to 14 cruising speed ..it was over 18 and guage turn n/a so need to cured that mid trouble and then will see for the main jet
Rustman
were the needles updated when the motor switch was done? 800 carbs take different needles than 750's. What size pilots are in it?
