YAMMIEGOD3:16
UNREAL !!! 3:16 (yammie tony)modsrx said:we try the sled today ...clutch are running good for engagement ...helix is a little to aggressive it shif way to fast running at low speed now ...but now we can't try it no more the motor seize dammmit ...............pto piston melt ....we had problem with overheating and the sled was on the lean size with the 150 main jet
Rustman
did ya change pilot size?
YAMMIEGOD3:16
RUSTMAN, PILOTS WOULD NEVER EVER CAUSE A BURNDOWN LIKE THIS. 3:16 (yammie tony)
Rustman
maybe not, but why a burdown with 150's for mains? Pilots should be changed though with those quad pipes on it.
YAMMIEGOD3:16 said:RUSTMAN, PILOTS WOULD NEVER EVER CAUSE A BURNDOWN LIKE THIS. 3:16 (yammie tony)
I believe the carb vents may be in the Airbox. With the vents in the airbox I run 157.5s on my ported/piped 800 for trail riding for safe jetting...155s are as lean as I would dare run.
Rustman
sideshowBob said:I believe the carb vents may be in the Airbox. With the vents in the airbox I run 157.5s on my ported/piped 800 for trail riding for safe jetting...155s are as lean as I would dare run.
so 150's are quite lean, I'm new to the 800 motor. thanks for the info.
Rustman said:so 150's are quite lean, I'm new to the 800 motor. thanks for the info.
ONLY if you are runnimg the car vent lines IN THE AIRBOX.
The stock VMAX4s have the carb vent lines hanging down under the carbs just like the SRXs
YAMMIEGOD3:16
AGAIN PROBLEY FUEL IS THE CULPRIT. WHAT ARE YOU USEING. PILOTS ARE A FRACTION OF JETTING SPEC ON A VMAX 4 WITH QUADS. THEY CONTROL YOUR IDLE. NOW VERY VERY CRITICAL IS MAINS AND NEEDLES. WHEN YOUR ON THE THROTTLE HARD ON A 4 BANGER YOUR PILOTS ARE A AFTER THOUGHT. 3:16 (yammie tony)
YAMMIEGOD3:16
PSI CALLED OUT 132.5 MAINS ON THEIR QUADS ON THE 800. NEEDLE/ raised DROP TO CLIP 4. IT WAS A DIFFERENT TIME FOR FUEL THAN. 3:16 (yammie tony)
all plug was very very light tanned brown almost white so that beast was running lean for sure ...........will put 157 or 155 and install a o2 gauge and see what it does.....temp at 0
bob i check and they are not vented in the air box .....does it make it richer or leaner
YAMMIEGOD3:16
VENT TUBES TO AIR BOX MAKE YA LEANER. 3:16 (yammie tony)
YAMMIEGOD3:16 said:VENT TUBES TO AIR BOX MAKE YA LEANER. 3:16 (yammie tony)
ok they are not there they are vented like a srx
YAMMIEGOD3:16
WHAT FUEL YOU GUYS USEING. 3:16 (yammie tony)
94 petro or vpower shell
YAMMIEGOD3:16
SHOULD WORK 3:16 (yammie Tony)
yep ....will jump jet size .........
YAMMIEGOD3:16 said:SHOULD WORK 3:16 (yammie Tony)
hey tony are u sure those 8bu-10 pull hard on top end in those srx ???
modsrx said:bob i check and they are not vented in the air box .....does it make it richer or leaner
Like Tony says...vents in AirBox are LEANER and usually require much LARGER Main Jets.
