staggs65
did you get the steering arm figured out?
That's great infoBETHEVIPER said:I have the spindles, they will work. apex spindles with viper tops.
for others, if you want to build a power rack, it is just parts from mid to late 90s polaris. This is what it is based off of. It will allow the use of long shocks like he is using. if he didn't use a power rack. his tie rods would want to bend over the bottom of the hole they run through when he unloaded the sleds suspension.
Looks cool, must have a foot of travel up front. Like the running boards.
