red rider
do you have anymore video's to post?
musselman said:Thanks guys, yah I just installed these seals last year so they only have 3500 km on them. I'll just clean it up and keep an eye on it, don't really want to do an engine tear down at this point.
No more videos right now but I got a GoPro this summer so I will get some nice vids this winter.red rider said:do you have anymore video's to post?
Thanks for the advice, I would feel better checking them and I already have plugs for the exhaust and intake. Plus I have a leak tester built to use on my blaster which will work great for this too. I will have to get my but in gear and get it done.mrviper700 said:the crankseals are a double lipped dual spring seal, doubt its leaking any air. Usually they leak because of age and the rubber starts to get hard and brittle and bits wear/fall out and the seal drws in air. You can check it pretty easily with engine out if you cant sleep at night.
just make covers for the exh outlets and some wooden dowel plugs for the intake boots, put a low amount of air pressure in engine via the crankcase nipple for fuel pump, only like 6-8lbs.of pressure. Spray seal with fantastic or something soapy and it will foam wherever there is a air leak. you can also put the air in thru sparkplug hole with piston at bdc on the pto for just that seal, just put rubber vac plug on crankcase nipple.
That's a great idea but I think it hits when turning the other way too. I guess I could have a radius across the entire front then have the split welded, then machine a slot behind with a hole drilled to pinch it on the spindle, but that's a lot of modificationstaggs65 said:what if you threaded the inside half of your steering arm with a helicoil and then radius-ed it on that inside edge where it hits like the ones from the sno-cross pic. not sure if it would work but it's an idea
The viper has fine splines where as the other has more coarse splines. I was thinking of getting some viper arms re-splined to match the coarse splines but I don't know if I can do that.SXRider7Hundo said:Boy that's gonna be a squeaker! How different are they? Would you be able to machine an insert to use the viper arms?
chris700readhead said:What was the best way to unroll the edges did you heat them to there nealing point or do it cold, and just rivet the edges on? How bout the steps on the back too? I really like the set up and might do it to mine, not a big fan of narrow running boards. Thanks chris
Thanks, I just hope I can get it done before the snow flyschris700readhead said:Thanks guys. Love the sled by the way musselman. Chris
